Old 08-23-2008, 09:59 PM   #61
well i did modified that novarossi 3sct, i changed the timing on the crack to 65 ATDC and made those "fancy fangs" on the sleeve, and also poslish the fang on the cranck. this engine on track was a bullet, smooth, tons of low end, great middle and also impresive high, very consistent, great power, literally was a bullet. and the best things of all, great millage. 6 min no problem.
i'm pretty greatful with this tread with the help of Stefan and Roelof, both were great help. thanks
mc_chofo is offline   Reply With Quote
Old 08-28-2008, 10:48 AM   #62
fly_wheel's Avatar
care to post us some pics of ur engine (crank, sleeve, etc) before n after mod??? thanks...
There are more in racing than winning.
fly_wheel is offline   Reply With Quote
Old 09-05-2008, 09:14 PM   #63
Rattlesnaker's Avatar
Awesome thread! Thanks for all the info and pics.
Rattlesnaker is offline   Reply With Quote
Old 09-25-2008, 10:07 PM   #64
-Crash-'s Avatar
Red face
Originally Posted by Cowboy View Post
Here are some real number for ya
inlet opens 145 degrees btdc
inlet closes 65 degrees atdc
exhaust opens 92 degrees atdc
transfers opens 118 degrees atdc
This makes a real good off road motor
if you want on road you can do
inlet same as above
exhaust opens 90 degrees atdc
transfers open 117 degrees atdc
I am starting another mod job and would like to get the real numbers of it.
I have the degree wheel, how do I use it to measure the nitro engine?
Hello, my name is Dan. I am addicted to rc
-Crash- is offline   Reply With Quote
Old 09-26-2008, 09:37 PM   #65
EdwardN's Avatar
That is disaster!!!
DO NOT TOUCH IT!!!!!! Then everything will be really good
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 09-27-2008, 08:04 AM   #66
-Crash-'s Avatar
Default ok................lol
I found a detailed article on how to read the timing numbers with the degree
wheel.
here they are inlet opens at 140 btdc
inlet closes at 63 atdc
exhaust opens at 84 atdc
transfer open at 110 atdc
any suggestions would be aprreciated
Old 09-27-2008, 08:09 AM   #67
wingracer's Avatar
Trader Rating: 24 (100%+)
What motor is it?
Could you post a pic of your degree wheel? I made one once from a 360 degree protractor and an old serpent flywheel but didn't like it so I need to make another.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Old 09-27-2008, 08:44 AM   #68
-Crash-'s Avatar
this is a HPI F 4.6 I am working on
Old 09-28-2008, 04:27 AM   #69
LogiK's Avatar
Trader Rating: 11 (92%+)
Can you post the article you found on how to time please?
LogiK is offline   Reply With Quote
Old 10-02-2008, 04:46 AM   #70
-Crash-'s Avatar
sorry, I miss spoke
the article is how to read the degree wheel. as far a adjusting time of the engine, it seems that is a gaurded secret in the modding comunity.
the little info I got is now sworn to keep secret
I did figuire it out with some help from some guys here and four other forums in pm's
thanks guys
Old 10-02-2008, 09:29 AM   #71
Maximo's Avatar
use mini diamond jewelers files to alter timing, its not rocket science by any means....
Maximo is offline   Reply With Quote
Old 10-02-2008, 06:26 PM   #72
For grinding the actual port in the sleeve you can use a Dremel and small diameter carbide bits to rough it out and finish it with a diamond bit. Make sure you chamfer the port slightly to get rid of any burrs with the diamond bit. For the crankshaft you can use the same method and then polish it up with Cratex
Cowboy is offline   Reply With Quote
Old 10-02-2008, 06:37 PM   #73
When you use a degree wheel make absolutely sure you have an accurate TDC. You can't just push the piston to the top and say that's TDC. You need to bolt something to the top of the engine that will hold the sleeve in place and stop the piston approximately 20 degrees before TDC. You need to get the same degree reading when turning the crank in both direction to the stop. Then 0 degrees will truely be TDC.
Old 10-03-2008, 05:00 AM   #74
Maximo's Avatar
IDK carbide does not cut chrome plating overly well.....most timing changes require not much more then just removing the chrome plating, IMO using a carbide would be next to impossible to get a clean cut when removing as little material as needs to be removed.........A fine diamond bit works well but I Most definitely would never ever recommend using a Dremel for cutting ports..........Dremels are also not a very good choice for cutting ports. because their motors are so amll Dremels need to use excessive RPM to make any power. too much RPM causes vibration and bit runout which makes cutting cleanly very tricky......... I use a Jewelers grade flexible shaft tool which works extremely well....however I still dont think using a carbide works well at all, even in a flexible shaft...
Old 10-03-2008, 09:57 AM   #75
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Can you show us a picture of what you use to modify engines???
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Nitro Engine Sell Great Parts engines. CHEAP NitroLuver R/C Items: For Sale/Trade 2 08-19-2008 10:00 PM
Engine Timing Issue jameslow Onroad Nitro Engine Zone 4 05-08-2008 07:16 PM
engine timing and duration guage rcosmax Onroad Nitro Engine Zone 3 12-04-2004 10:46 PM
ftrc10gt and xxxnt both with engines for trade for nitro touring with engine tony montana R/C Items: For Sale/Trade 1 06-06-2004 11:09 PM
Changing Nitro % - How To Adjust Carb thefuzzclub Nitro On-Road 3 07-08-2003 06:08 PM
