Dumb question
Old 01-01-2008, 11:23 AM
bozla's Avatar
Default Dumb question
How do I get this off?
bozla is offline
Old 01-01-2008, 11:31 AM
impalabob64's Avatar
Default answer
spray alittle wd40 ,then take a flathead screw driver wrap it with rag or towel ,hit it from the bottom it should pop out.
impalabob64 is offline
Old 01-01-2008, 11:58 AM
bozla's Avatar
Cheers - worked a treat!
bozla is offline
Old 01-02-2008, 10:32 AM
bozla's Avatar
Another dumb question. How to remove the rear ball bearing in the crankcase?
bozla is offline
Old 01-02-2008, 11:30 AM
V for Victory's Avatar
I heat the crankcase in the oven until the metal expands then knock the bearing out.
V for Victory is offline
Old 01-02-2008, 12:56 PM
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Default bearing
you can use the oven or if you have a gas stove works even faster. get the temp up to 275 300 degree i put a 2x4 on the ground and when the crank is heated up use gloves or oven mitt and hit the 2x4 with the flat part of the back plate area and it should fall out.
Speedypeterb is offline
Old 01-02-2008, 01:55 PM
bozla's Avatar
Nice. All done!
Another dumb Q: Are engine bearings standard?
bozla is offline
Old 01-02-2008, 02:10 PM
ezveedub's Avatar
Trader Rating: 17 (100%+)
Originally Posted by bozla
Nice. All done!
NO. What engine is it or meaure the outside, inside and width of the bearing. If its old, it maybe 13mm inner, later are 14mm, but like I said, measure it and post the size or the engine.
ezveedub is offline
Old 01-03-2008, 09:05 AM
bozla's Avatar
I want to put a bearing meant for a ninja engine into a mega zx21.?
bozla is offline
Old 01-03-2008, 02:38 PM
ezveedub's Avatar
Got both engines, but I didn't check the ZX21 bearing size and I'm not sure if they are the same. ZX21 though can be different, since there are revised ones and different manufacturers.
ezveedub is offline
