-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   Red dot break in Help! (https://www.rctech.net/forum/onroad-nitro-engine-zone/177151-red-dot-break-help.html)
Hpimichael 08-15-2007 07:49 AM
hey guys,
im breaking in a new red dot for my rolling Frame R40, heres my question, im just running it at quarter throttle and less and running really rich, but when i blip the throttle it was to flame out but just drops in RPM and then kicks back to the higher rpm this only happen when i blip the throttle.... is this good or bad, and how do i fix this ?? will it go away when i lean it out???
and the pinion gear got soo hot that when shut the car off after a run the gear melted.... never had this problem the first time i broke in my other red dot... im baffled...
thanks
mike
M7H 08-16-2007 05:26 AM
Originally Posted by Hpimichael (Post 3582908)
hey guys,
When you open the throttle not more then 25%, even when you have opened the HSN to a richer setting, the engine will run a bit "lean".
Now when you blip the throttle with this very rich HSN setting, the engine get's a lot of fuel, and want's to flame out, sound perfectly normal to me....
thanks
mike
When running in an engine, set your clutch to early engagement, to prevent it from to much slip, and overheating.....
