Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Where to buy BOSS 21 crankshaft? >
Old 08-05-2007, 01:46 AM
Ryan41's Avatar
Default Where to buy BOSS 21 crankshaft?
Hi, just wondering if anyone knew where i could purchase a BOSS 21 crankshaft from? A mate of mine has one..and the very end of the crankshaft snapped off (just before the flywheel nut)...very weird.
thanks in advance
Ryan
Ryan41 is offline
Old 08-05-2007, 07:58 PM
German Muscle's Avatar
a ninja crank will work
German Muscle is offline
Old 08-05-2007, 09:51 PM
Ryan41's Avatar
Ok, I was hoping that! Plenty of Ninja stuff over here
cheers
Ryan41 is offline
i knew a guy that had the crank snap off in the same spot on his ninja so i gave him a crank out of a boss that dropped a rod. the next time i bumped into him he said that it did not fit..... different crank pin size i think was the reason.
stick with a novarrosi based engine
mugengreg is offline
Old 08-05-2007, 11:17 PM
should be the same as long as its the same engine.
like On road crank in a on road engine, and off road to an off road. They are the exact same engines basically.
Old 08-05-2007, 11:46 PM
i thought they were the same and that is why i gave him a crank. boss 5port off road engines and ninja 5 port engines have different cranks . if you take the crank,piston and rod from one and fit to another it should work
Old 08-06-2007, 02:49 AM
M7H
M7H's Avatar
there's been a batch of cranks, which had the hole to tighten the clutch, drilled to deep into the crank. That way, the crank is weak around the flywheelnut....
M7H is offline
Old 08-06-2007, 05:15 PM
Ryan41's Avatar
Well we have pulled my old ninja crank out and put it into his boss. Measured the pin with verniers and the overall diameter etc..was identical.
Also, the only differnce between the 2 is... the Ninja has a little more porting work... same port layout..but the ninja is a little more opened up.
Ryan41 is offline
Old 08-06-2007, 10:38 PM
Old 08-06-2007, 10:47 PM
glad that worked out for you
it would seem that i have been lyed to
Old 08-23-2007, 09:47 PM
fatboy's Avatar
Try Falcon, It's more the same as Boss.
fatboy is offline
