Old 07-06-2007, 10:15 PM   #1
Sp Racer's Avatar
Default Conical header vs Std header - what's the difference?
Can anybody shed some light?.
Sp Racer is offline   Reply With Quote
Old 07-07-2007, 01:49 AM   #2
occ
Trader Rating: 15 (100%+)
The inside diameter on the engine side of the manifold is smaller than the diameter at the exhaust end. I heard it gives 30% more power than a staandard manifold.
Its just like exhausts on Go karts & Motocross bikes.
occ is offline   Reply With Quote
Old 07-07-2007, 06:07 AM   #3
also, better bottom end (more punch) and similar top end to a std header, if not more.
TomB is offline   Reply With Quote
Old 07-22-2007, 02:15 PM   #4
Corse-R's Avatar
Conical headers help for more cylider scavenging of the burnt gas, they give you more overall power but at a cost, they draw more fuel so you will get more power but can face runtime problems too.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 07-23-2007, 01:55 AM   #5
Sp Racer's Avatar
Gracias Hombre !
Old 07-23-2007, 04:56 AM   #6
AMGRacer's Avatar
The conical manifold is beneficial due to the fact that the exhaust gasses "stick" to the walls of the pipes it is travelling in. This stuck layer does not move the same as the remainder of the gas, thus it effectively reduces the pipe size by the thickness of this layer. The layer thickness depends on several factors, density, temp and other reasons.
A conical shape to the pipe massively reduces the thickness of the gasses that want to stick to the pipe walls, effectively increasing the usable internal diameter of the pipe.
AMGRacer is offline   Reply With Quote
Old 07-23-2007, 07:50 AM   #7
is this the same theory of a small water pipe having more internal drag on the fluid as compared to a large pipe?
i didn't understand your above explanation to well
Old 07-23-2007, 09:59 AM   #8
Pooh2's Avatar
Send a message via MSN to Pooh2
WoW!!
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 07-24-2007, 05:12 AM   #9
AMGRacer's Avatar
Not really. It is a fluid dynamics theory. The gas closer to the walls of the pipe "sticks" to it, basically increasing the difficulty in getting it moving with the pulsing of the exhaust openings.
Old 07-24-2007, 05:41 AM   #10
hav_lova's Avatar
im just trying top grasp this concept, so with the conical header opening up as it goes along the gasses that stick to the side move away from the center, removing some of the friction?
Just playing with bigger toys now...
serpentrc.com.au
hav_lova is offline   Reply With Quote
Old 07-24-2007, 05:58 AM   #11
AMGRacer's Avatar
It is kind of an involved subject, it is to do with a fluids change in flow properties when it is close to a fixed surface. Have a bit of a read here:
http://en.wikipedia.org/wiki/Boundary_layer
Old 07-24-2007, 06:02 PM   #12
wallyedmonds's Avatar
what he said
i know but i cant put it to words
im not a very good writer
wallyedmonds is offline   Reply With Quote
Old 07-24-2007, 08:30 PM   #13
Rawz's Avatar
Very interesting, and complex!
What I read about conical headers is that, with the small opening in the gas intake, and a larger one at its other end(to the pipe), the gas flow gets accelerated(SP?). That is because pressure difference, if I remember right. The smaller part have more pressure than the larger one, so the gas flows "accelerated" from the high pressure zone to the lower one, to attain equalization with the atmospheric pressure as fast as it can.
Thats why the scavenging process is better on the conical header, it sucks more gas from the chamber, thus getting more fuel on it, faster. Thats also why it will, on a direct with a standard header(consider variables equal, temp, pipe ...) consume more fuel, its getting more fuel into the pipe also.
Thats right ?
(I am very bad with writing too, and that in my mother language, in English then ...)
Rawz is offline   Reply With Quote
Old 07-24-2007, 10:22 PM   #14
stefan's Avatar
Send a message via AIM to stefan
Thats right ?
The conical header works like a ventury, your description is absolutely correct.
stefan is offline   Reply With Quote
Werks Conical V header? mblgjr Nitro Off-Road 3 09-13-2008 12:35 PM
Mugen 1005 & Werks conical Header pncstod R/C Items: For Sale/Trade 15 06-22-2008 08:21 AM
Why do they call it a conical header? THE DOCTOR Onroad Nitro Engine Zone 2 10-27-2006 08:09 PM
TOP EFRA 9886 NIB W/ CONICAL HEADER luketob R/C Items: For Sale/Trade 2 07-20-2006 03:57 AM
.21 Picco 7206 Conical Header 1FastVW Nitro On-Road 1 02-04-2004 09:08 AM
