Old 06-02-2007, 09:13 AM   #16
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
OK cool do you do onroad engines as well
Nitro$junkie is offline   Reply With Quote
Old 06-02-2007, 11:37 AM   #17
Colt4g63's Avatar
Yes sir. I have a small vid of one of a TC3's i had with a sirio EVO 3 i did in it goin up and down the street testing it out. Here ill shoot u that vid and let u check it out for yourself. Its a 2 speed i have the 2speed setup to shift very soft so i could keep traction around the sweeper at our local track. Dont want a high powered engine shifting all abrupt and throwing u into the wall
I really like these TC3s for the parking lot tracks around here. They work very well in the lots IMO.
http://www.youtube.com/watch?v=WSYSPCjL4e4
Colt4g63 is offline   Reply With Quote
Old 06-03-2007, 03:47 AM   #18
very nice might have to send you me Ninja to work your magic on
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Old 06-03-2007, 12:17 PM   #19
Colt4g63's Avatar
Send it on. My prices are MORE then fair!
Old 06-05-2007, 06:23 AM   #20
Jerseyboy's Avatar
I own one of these beasts.
In a buggy its excellent, very linear powerband with a wicked upper midrange and topend.
I used it in my truggy and it lacks the bottom end for a truggy. If you use it with a werks clutch and adjust for later engagement then it will work.
This is apparently JP's most powerfull engine. The internals are top notch. The casing inside has been worked, the crank is a work of art. The sleeve porting is beautifull.
I changed the sleeve with a P5 sleeve and must agree with razzor that the 5 port is a much better option. You can use any P5 sleeve and it will work in this engine. At least keep the option in mind. With the 5 port sleeve this engine uses more of its power. With the 8 port you get to 3/4 of the straight and it wants to only start delivering.
Jerseyboy is offline   Reply With Quote
Old 06-05-2007, 09:54 AM   #21
Colt4g63's Avatar
I use the novarossi 821 in my 5T truggy. But i do timing changes that really brings the bottom end to life, but yet still has a nice top end pull to it! I run 1mm springs and light aluminum shoes and a 53 pipe and it works great. On the track we run on it has a long straight so we all go up to 14 tooth bells and the 821 has MY modded 821s have NO issues pulling it right out of the corners! I actually really like these mills alot. Very smooth power delivery, but if u grab a hand full itll get u over a triple NP. I thik its a highly underated engine IMO. But then again mine are all modified to different timing specs...
Old 06-06-2007, 07:53 AM   #22
which break in process best suits this engine
WOT method http://www.cefx.net/tips/nitro/break-in/index.php
Or heat cycle http://www.johnnycoolguy.com/JCGR/ma..._break-in.html
Futaba
Mugen
Novarossi
Byron's
Old 06-06-2007, 12:25 PM   #23
German Muscle's Avatar
Heat Cycle
German Muscle is offline   Reply With Quote
Old 06-06-2007, 02:19 PM   #24
Ok i was thinking that one but just wanted to make sure
Futaba
Mugen
Novarossi
Byron's
Old 06-06-2007, 03:12 PM   #25
Corse-R's Avatar
Got a 5-T yesterday along other niceties just to try it with my 'Moguls Panzer' (aka MBX5-T) wanted to try one of those just to compare it with the Ninja B01 I have since day one.
This weekend is impossible to test it, but, next weekend I'll be breakin-in just to see how flexes their muscles and compare them with the B01.
Got the EFRA 9901 pipe along the std long manifold (double turn). Any comments regarding this combo? Many swears by the 9886 pipe, but.. is very hard to find actually here (too loud!).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 06-06-2007, 03:16 PM   #26
This engine works best with Novarossi 9886 or 9853 tuned pipes. The 9853 tuned pipe will provide more power on the bottom end with about the same top end as the 9886 pipes, however runtime will suffer. The best overal pipe for excellent runtime with smooth power delivery is the Novarossi 9886 with short header. The longer header will give a little more bottom end at the expense of runtime. The MSR1005 pipe also works well on this engine, but it also suffers from less runtime than the 9886 tuned pipes.
Futaba
Mugen
Novarossi
Byron's
Old 06-06-2007, 03:29 PM   #27
Hers a link to some reviews in the offroad section
http://www.rctech.net/forum/showthread.php?t=110390
Futaba
Mugen
Novarossi
Byron's
Old 06-06-2007, 11:59 PM   #28
what oil content is recommended with this engine novarossi web sit states to run a max of 10% oil in their engines thats what i have got for this engine will that be ok?
Futaba
Mugen
Novarossi
Byron's
Old 06-07-2007, 12:05 AM   #29
Corse-R's Avatar
I use the same fuel brand I use on the 200mm and the 1/8 On-Road, Runnertime. Maybe there is difficult to get, but stick to a 'race blend' of a reputable vendor and you'll be fine. Choose whatever suits your personal preferences better.
Vendors doesn't state how much oil and which oils, but... should be around 10%. Few (very few...) state them.
Cheers,
Corse-R
Old 06-07-2007, 12:15 AM   #30
i noticed that no well named brands state their oil content I'm using AT Racing with a 25% nitro and a 5/5 oil mix i use it in my onroad 1/8 as well should be OK
Thanks Corse-R
Futaba
Mugen
Novarossi
Byron's
JP FX21B-8T Nitro$junkie Electric Off-Road 2 05-31-2007 04:20 PM
JP FX21B-N 5P BUGGY STANDARD MODIFIED Engine for sale matirx_mimi R/C Items: For Sale/Trade 3 04-23-2005 03:16 PM
