Old 05-18-2007, 01:10 AM   #1
casimirsa's Avatar
Default REPLACING BEARINGS
I have been pondering over the subject of replacing bearings in a motor for a long time!
My questions is:
1. Is it better to replace the bearings by knocking them out or to heat up the crankcase?
2. If you replace the front bearing with a METAL seal bearing do you take out the inside seal or not?
3. If you replace the front bearing with a RUBBER seal bearing do you take out the inside seal or not?
"Horsepower is how fast you hit the wall. Torque is how far the wall moves after you hit it."
TM G4S (ED), TM G4S,SERPENT M2+835+960FD, MUGEN SEIKI MRX4-X, MUGEN SEIKI MRX4 (WORLDS CHASSIS), MUGEN SEIKI MTX4, MUGEN SEIKI MBX5T, HPI PRO4, TAMIYA, PALMARIS, RB C5+C5 RODY+V12 RODY, NOVAROSSI, JP, AXE ROSSI, MEGA, NOVAMEGA KHM, KO PROPO, HITEC, GRP, UFRA, ROBITRONICS, SJ, LRP
casimirsa is offline   Reply With Quote
Old 05-18-2007, 07:04 AM   #2
My questions is:
question 1 = yes, heat up the case to about 200 degrees celcius or more, (pre heat oven) then let it sit int he oven for 5 or 6 minutes, then tap it out with anything.. peice of wood, large diameter allen key etc
question2 the inside bearing has both shields removed with the balls visible, and facing the backplate.
question 3 the outside bearing (front) take one sheild of and place the balls visible, facing the backplate, leave the outside rubber seal of course
ps when i say "balls visible" i mean this. look at the bearing notice it has the "cage" which holds the balls, one side covers the balls the other side has the balls exposed, ie visible. this is what i mean by the "balls visible" side.
now to put the new bearings in, pre heat the case again, this time a bit longer (without carby preferably) ie heat up for 10 or 15 minutes, then put the new bearing in the crank (the large internal bearing ) and drop the cold crank and cold bearing into the hot motor. pull the crank from the clutch bell end so as to make sure the bearing is sitting striaght, then quickly pop the outside bearing into the case. MAKE SURE WHEN YOU PUT THE SMALL OUTSIDE BEARING IN, THAT THE CRANK DOES NOT DROP OUT! lol. if necessary hold the crank with a peice of wood or some heat proof cloth or something.
it is also a smalrt idea to wear pit gloves whilst you do all of this, as well as obviously, holding the hot engine with ample amount of towel to stop burning yourself.
pps; take the rubber carby boot of just incase it melts or some weird stuff happens (like i said above, preferable to take entire carb of).
TomB is offline   Reply With Quote
Old 05-18-2007, 05:28 PM   #3
MassiveMods's Avatar
If i may add something to this ,
oil the new bearings before putting them in.. it will help them move into place.
if you are removing bearings for servising and then putting them back its a good idea to oil them before you heat the crank case , this will protect the inner race if its polymide from excess heat ...
M
Engine development manager Rifling Pty Ltd. Nitro fuel designer : Neo + World record title holder 2012 Austalian Nationals 147.6 KPH , 1 st 2 nd and TQ Australian National Buggy titles 2012. Victorian State title 2012 Neo + , South Australian state title ON and Off Road 1/8 2012 Neo + :-) QLD State Titles 2012 1st buggy & trruggy + TQ Neo + MG66 RX7 1st Sportsman Class Truggy QLD State Titles 2012 !! Nitro Addicts Australia . com
MassiveMods is offline   Reply With Quote
Old 05-19-2007, 06:57 AM   #4
itchy b's Avatar
[QUOTE=TomB]
THis is another example of the side with the Balls visible!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 05-19-2007, 07:16 AM   #5
[QUOTE=itchy b]
i knew i was gonna incur the wrath of a balls joke sometime or another! trust you joe to do it lol
Old 05-20-2007, 01:46 AM   #6
casimirsa's Avatar
oil the new bearings ..
if you are removing bearings for servising and then putting them back its a good idea to oil them ......
M
This might sound stupid!! Why will you remove bearings for servising?
Old 05-20-2007, 03:06 AM   #7
itchy b's Avatar
[QUOTE=TomB]
I kept that pic just for such an occasion
EX1.5-SC10 4x4
Old 05-20-2007, 03:07 AM   #8
itchy b's Avatar
[QUOTE=itchy b]
Btw i just couldn't resist the opportunity!
EX1.5-SC10 4x4
Old 05-20-2007, 08:41 AM   #9
Davidka's Avatar
Trader Rating: 77 (100%+)
It's really only for replacement, to change them when they are worn.
Old 05-20-2007, 07:02 PM   #10
Sometimes they may feel gritty or gummed up .. you can take them out and soak them,, if you clean them inside the engine 1 you wont get to clean them as well and 2 you risk flushing debris into the motor,...
Old 05-20-2007, 09:29 PM   #11
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Gritty bearings cause vibration and put extra load and stress on the motors. All not good.
Artificial-I is offline   Reply With Quote
Old 05-20-2007, 09:33 PM   #12
Team Kamikaze's Avatar
If the bearing gets gritty, that means the bearing's life is done.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-20-2007, 09:36 PM   #13
Moderator
Yes, then it goes to bearing heaven and plays shuffle board with its old friends.
Replacing Engine's rear bearings? MetalShield Nitro Off-Road 7 02-19-2008 01:57 AM
Replacing Engine's rear bearings? MetalShield Nitro Off-Road 2 02-18-2008 08:08 PM
Replacing Engine's rear bearings MetalShield Nitro Off-Road 0 02-18-2008 02:24 PM
KANZEN Bearings vs Boca Bearings vs Other Bearings rmdhawaii Nitro On-Road 6 04-29-2006 09:38 AM
Replacing engine bearings......? j240z Onroad Nitro Engine Zone 3 01-18-2005 08:12 PM
