Murnan Modified Motors
#1261
Originally Posted by rmdhawaii
That's a great tuning tip DJ. I'll have to add it to the engine KB.
#1262
Originally Posted by serpentpro28
Hi' Uriah i have a question on my 35plus21 full mods,everytime i stop the idle is too high and i't takes a while to goes down,unless if i hit the trottle once,looks like to the bottom is lean but i open it up' i'm loosing power' need ur help'
thanks
thanks
#1263
Originally Posted by dj apolaro
Remeber thats is assuming that the motor is not coming in hot and idling high for that reason.
#1264
Originally Posted by Grinder
Hi. It could be that the low end is too rich still. Do you see lots of smoke out of the corners? You should see some. Try leaning the low end needle at the same time close the idle screw slightly. If it is better, then do it again. Just make sure to check your glowplug after each run to make sure it is not getting dry. It should look shiny.
Thanks to you 2 dj' for the info'
#1265
Hi.I have JLR .12 Red Dot Engine. What type of glow plug is best for 16% nitro. I have PT6H Picco Plug, is it good for me?Thanks
#1266
#1267
Thanks Uriah i will try that' btw what is the good temperature after the brake-in?
#1268
Attention all team drivers. Please email me pictures for the new team page.
Thanks, Uriah
Thanks, Uriah
#1269
Just send me an engine and you'll get a pic
#1270
Ninja .12 Powerpacks are back in stock.
#1271
Thanks, Uriah
Thanks, Uriah
#1274
Gracias Javier...
#1275
Originally Posted by Geovannie
Gracias Javier...
Is is july yet!!!!!!!!!!!
