Werks B7 Pro
Old 07-14-2007 | 05:12 PM
  #31
i ordered the b7 pro from AMAIN and exspect it next week can anyone tell me what the top and bottom screws are from closed for a slightly rich setting when i run it in on the heat cycle method, do they like the rossi range of plugs and is the rossi 2015 pipe a match for it thx in advance
pitdog is offline
Old 07-14-2007 | 07:32 PM
  #32
Jason Halvorson's Avatar
i like to run the OS P8 cold plug in my B7 PRO, and for pipe i would run either a werks 2013 or a second choice of a Jammin JP3....
Jason Halvorson is offline
Old 07-15-2007 | 03:24 AM
  #33
how does it compare to the others,fuel,power,tune and what are your screws at from closed thx jason
pitdog is offline
Old 07-15-2007 | 08:26 AM
  #34
i run byrons 30% and have no problems running down vspecs on the straight, as for my needles i have no idea...i dont feel the need to keep track of those things as long as the engine is running well and im getting good run time (about 8min. per/tank)....
Old 07-16-2007 | 01:31 AM
  #35
no worrys thanks mate
pitdog is offline
Old 07-31-2007 | 01:26 PM
  #36
i rate this motor on par with my nova plus21-7bt for torque but with a lineal power band like the ninja,im using a c6tc nova plug and hot buttered 444 feul with the nova 2015 pipe and very happy with the motor so far(broke it in with the heat cycle method no problem)i would recomend this motor very good value for the money
pitdog is offline
Old 08-06-2007 | 02:28 AM
  #37
does anyone have a race tune needle setting for top and bottom from closed i need a referance to work off,this motor is taking for ever to come off it`s metal pinch(cant wait to see it release into it`s full potential,should be fully sick mate)
pitdog is offline
Old 01-22-2008 | 05:49 AM
  #38
lethalleigh29's Avatar
This would have to be one of the most potent engine that i have ever owned i sent it off the massive mods to see what power could be released from this powerhouse and all i can say is WOW,
So smooth on par with my ninja with has it on punch from the line but the werks motor just eats everything else that any motor can dish out i am running a losi eight buggy and can just roll on the throttle and im off like a rocket
What a motor what will they release next
has anyone tried the 28 version.
lethalleigh29 is offline
Old 01-22-2008 | 11:57 PM
  #39
wow a modded werks b7 pro sounds a little to quick for me,that would fun to watch but sounds fully sick mate
pitdog is offline
Old 01-24-2008 | 03:31 AM
  #40
has enyone found what plug works best for this engine i am currently run an OS P3 plug
what are all your recommendations
Old 01-24-2008 | 05:32 PM
  #41
20 SMOKE's Avatar
in my b3 i use nova's
20 SMOKE is offline
Old 01-28-2008 | 01:22 PM
  #42
P3 went fine on the weekend held a good tune but at 14 bucks a plug down under there has to be an alternative
what nova plug do you run smoke
Old 01-28-2008 | 01:43 PM
  #43
20 SMOKE's Avatar
#6 or #7 depending on the air themp and humidity
20 SMOKE is offline
Old 01-29-2008 | 08:54 AM
  #44
Cheers Smoke,
Have you tried the o,donnell 97T im told they work well in my ninja so im keen to try them in the Werks B7
Also have you tried the ninja plugs.
Old 01-29-2008 | 02:41 PM
  #45
20 SMOKE's Avatar
used os for a shot time but i stick with nova's now
20 SMOKE is offline
