New Leaking Orion Wasp .12 CRF
I just bought this Orion wasp .12 crf engine last week brand new and broke it in friday and after about 4 to 5 tanks I noticed a bad wet spot on the lower part of the carb area above the flywheel then saturday I race at our local track and that is when I notice the whole lower engine was wet and all around the flywheel area along everywhere else in that area. I called Team Orion tuesday and was told they have no issues with front bearings and I would have to buy a new or send the engine for them to see, I really dont wanna send the engine when I could install it my self, and be out a engine for a week or so..
http://www.imagestation.com/picture/...d/ea7596b1.jpg http://www.imagestation.com/picture/...d/ea75969f.jpg http://www.imagestation.com/picture/...b/ea75968c.jpg http://www.imagestation.com/picture/...d/ea75967e.jpg http://www.imagestation.com/picture/...d/ea759675.jpg http://www.imagestation.com/picture/...4/ea75966f.jpg http://www.imagestation.com/picture/...3/ea759666.jpg http://www.imagestation.com/picture/...f/ea759655.jpg |
you may just be too rich on your needle settings
None of my CRF engines got the fuel leaking problem ...
The pics didn't show clearly your needle settings ... but apparently you might be running a bit too agressive on slow speed needle setting with which you might need to set the high speed needle on the rich side in order to keep the engine running within a "safe" temperature range. Suggest you to reset your needle settings (I set the slow speed needle of my CRF engines much richer than yours ... I could see the slow speed needle set screw of my CRF engine from the bird view; I am very agreesive on the high speed needle setting though). If the leaking problem persists after you reset the needles, Team Orion should get you a replacement front bearing or other parts which caused the leak ... |
we will see what happens I am going to change the bearing and try it again, it just sucks because it is a band new engine and I have never had this problem with other engines |
The pics didn't show clearly your needle settings ... but apparently you might be running a bit too agressive on slow speed needle setting with which you might need to set the high speed needle on the rich side in order to keep the engine running within a "safe" temperature http://www.imagestation.com/picture/...0/ea7523d1.jpg http://www.imagestation.com/picture/...f/ea7523c2.jpg http://www.imagestation.com/picture/...f/ea7523b6.jpg |
3 Attachment(s)
This is my needle settings for your reference. The fuel I used was Odonnel 30% & the head shim of my engine was 0.4 mm.
it's hard to tell from the picture. can you clean it up and put tons of after run oil in the engine, if the oil is coming out between inner race of bearing and crankshaft, you might have a bad apple that slip thru the QC. If oil is leaking out of the between the inner race of bearing and the plastic sheild of bearing, you got a bearing problem.
If there is no immediate leak or no sign of leakage in an hour, it's probably from running too rich on the bottom end. |
i will try that tomm I will fill it up and let it sit, and we will see what happens before i change the bearing,
btw: this has no updated carb parts |
If there is no immediate leak or no sign of leakage in an hour, it's probably from running too rich on the bottom end. http://www.imagestation.com/picture/...7/ea6e587c.jpg http://www.imagestation.com/picture/...5/ea6e586b.jpg |
from the new picture, it seem you have worned out seal around the inner race bearing. its possible it's cause by the tapper cone washer, put a shim between the bearing and the tapper cone washer next time to prevent premature wear/tear on the sheild.
MRX4,
Please email me at [email protected] and we will work out something to get the issue fixed. I imagine that you already have the updated carb on your engine, if the carburator insert is conical then you have the new one, if the insert has a cup shape you have the old one. Anyhow we have drivers that have no issues with the older version. Nano |
Nano email was sent, thanks for responding
Well today I cleaned the engine real good and put after run oil in there and let it sit, I came back thirty min later and the after run oil was already leaking through the rubber seal, thank god it was not leaking at the crankshaft, here are some pics but they are not that close but you should get the picture, what should I now with Orion..
http://www.imagestation.com/picture/...7/ea6e587c.jpg http://www.imagestation.com/picture/...5/ea6e586b.jpg Every first time before you start a engine, you should take out the glow plug and bump the engine on start box and force all after-run oil out. Then you won't have oil leaking problem all along the whole day. Actually a little bit of oil come out from front bearing is normal......... of course you may need a new bearing if too much oil leaking. |
| All times are GMT -7. It is currently 11:32 AM. |
