IDM Picco
Old 03-10-2007 | 10:08 AM
  #31
GMartinez's Avatar
Originally Posted by jag
This information is inconsistant with what is in the manual. The engine comes stock with a .20mm and .10mm shim (.30mm total) for use with 20-25% nitro. They recommend adding another .10mm shim (.40mm total) for 30%. Where did your information come from?
Jag for the winternats we added 2 mega shims because the dimension from the factory are not the same when you actually measure the shims it be slightly less than the manual states. I think we actually measured .45 after we added the 2 shims.
You can also call pete from pnp he also ran the IDM @ the winternat's as well
GMartinez is offline
Old 03-10-2007 | 08:20 PM
  #32
AFM
Tkx for your replay. I'll be in touch.
memarques is offline
Old 03-11-2007 | 03:21 PM
  #33
jag's Avatar
jag
All this information had me a little confused so I checked it this morning and here is what I found. With .40mm of shims (stock plus (1) .10mm shim) I have a real clearance of .57-.58mm as measured with my caliper using the "squash the solder" method. This is what Picco recommends and it is close to the clearance afm has on his chart. I am going to start here and watch closely for detonation and top speed. If needed, I will add another shim.
Thanks for the input.
jag is offline
Old 03-11-2007 | 09:52 PM
  #34
moy's Avatar
moy
is it easy to get parts for this motor? and where?
moy is offline
Old 03-11-2007 | 10:13 PM
  #35
Team Kamikaze's Avatar
you know where
Team Kamikaze is offline
Old 03-12-2007 | 06:12 AM
  #36
jag's Avatar
jag
You can get anything you need for this engine at PNP Hobbies (321) 723-7318. Pete will take care of you, he is a great guy.
jag is offline
Old 03-12-2007 | 01:16 PM
  #37
robert maestrey's Avatar
Pete Pepe Rocks!!!!
robert maestrey is offline
