URGENT! TECHWELL .12! HELP!
Old 10-02-2006, 04:42 AM
Location: Sydney, Australia Home for none of you rc needs!
Exclamation URGENT! TECHWELL .12! HELP!
Hey guys,
im looking to purchase a Techwell .12 for my Fw-05s atm it has a side exhaust on the gs15r ...
I want to know what you guys think of these engines...there negatives and positives and what else i should purchase when i buy this engine ...What else would i need cause i think i need engine mounts? atm i dont have a sg crank shaft..so what would i need to fit this engine on my car!! thanks guys please tell me if this motor is worth it! i think it is going for about $150 just motor (pullstart) thanks!
Chris
chrisanton is offline
Old 10-02-2006, 06:41 AM
i also have a 2speed on my car..dno if this would affect anything....
Old 10-02-2006, 06:58 AM
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i cant even find a techwell .12 on the net. i havent seen one nor have i heard of them before. i fyou are running a std threaded crank with a pull start ? then i would suggest an OS 12cvrx, they are a littlebit more in price but believe me its worth the bit extra. the quality of the motor would be better and being a direct fit for a threaded crank and pullstart, they put out nearly 1hp, reliable and easy to tune and they hold their tune. if you have a bit extra dough, then i would spend it on a better engine. i am going through the same thing at the moment and maybe i should have spent the cash to start with in the beginning.
Pattojnr is offline
Old 10-02-2006, 08:51 PM
the techwell has just abit over 1hp....i thought they were a copy of the novarossi until i pulled one apart myself and noticed they werent! ...i dont think i will be buying one of these engines anymore i called over 10 hobbystores and they all said what the **** is a techwell .12 LoL .....i guess ill just call my LHS and find out
Old 10-02-2006, 09:51 PM
itchy b's Avatar
itchy b is offline
Old 10-02-2006, 09:52 PM
itchy b's Avatar
Originally Posted by chrisanton
the techwell has just abit over 1hp....its a copy of the navorossi engines.....i guess ill just call my LHS and find out
techwell engines are not what would be called long lasting motors.
you can get one and it will be ok but remember, you get what you pay for
best option would be to buy a proven brand of engine
it'll cost you a little more but you'll save money in the long run
itchy b is offline
Old 10-04-2006, 06:24 AM
hey guys,
i was thinking about purchasing the LRP z.18s PRO i dont know if this will be a better option, it will fit straight into my fw-05s also cause it has a standard crankshaft so ther eis no extra cost of purchasing flywheels, bearings etc...what do you guys think about the LRPz.18s PRO and also what should i run a .18 size motor in with ? what nitro % thanks.
