why the scoop in the button head for modified engines ?
#31
i think from the video given by maximo i think its enough to tell that there's a different in the top end. it slike never ending power. still screaming even at the most end of it.
just from my newbie observation of coz
#32
Originally Posted by mrgsr
hey guys my engine had a weird day of running today..
it did 3 qualifying heats with crazy power running no more than 95-100 degrees celsius (os vz-r .21)
then in the final it blew 2 plugs straight away. the engine came out fast as hell for about 2 minutes then just went slower and died. this when it blew the plugs. we tried to go richer on the top end but it blew the second plug to..
now im wondering if the turboscoop has made more volume therefor maybe i shuld remove a shim ?
what do you think
thanks..
what do you think
thanks..
The crank pin seem to be a weak spot. It wears much quicker than other brands.
The fact that they perform does not make up for the quick deterioration of certain parts on the motor.
#35
Originally Posted by gashuffer
If you have to remove shims to compensate for lost compression, Doesn't that defeat it's purpose?
Look at the post I put to a magazine and see the website that someone posted on the first replies.
Sorry for reviving such old thread, but like many others buried here contains lots of good information. Maybe MXwrench and some others may look for those and put a sticky thread just for info, seems that many people are here for wrenching their own engines and look for information.
#36
Giving life back to this post
#37
I would like to do this mod to my engines, I remember extreme r/c magazine doing an article about the grooves and they found that 3 grooves close together had the best results on their dyno. So my questions are, where is it best to face the grooves to the exhaust port or to the main intake port? Also whats the best way to create the grooves? would i just be able to use a dremel with a cutoff wheel. From looking at Singhs work it looks like precision is not that necessary.
I plan on using this in 1/8 offroad so I am really hoping to see if i can't improve mileage more than increase power. If any one has done this mod to a model engine did you notice a runtime increase and also how much runtime did you get.
#38
i already done mine by using triangular file. I plan to remove head shim, but how to check whether my engine is pre-ignition/pinging? is there any wierd sound?
