O.S. .12 TZ(P)-T3 Speed Tuned
#106
Thanks Ray,
I was hoping you would see us all asking and get this staightened out.
#107
Good news to all O.S. Speed owners currently looking for a new piston/sleeve set. Is is now available at a kick@$$ price..
Here's the link:
http://rc-mushroom.com/product_info...oducts_id=12409
Enjoy..
Here's the link:
Enjoy..
#108
Location: Cebu City, Philippines and Ocala, Florida, USA
Now that is what you call a very good price for a modified piston and sleeve set
http://rc-mushroom.com/product_info....ducts_id=12409
#110
I second that..
#111
Originally Posted by mrgsr
doki thats just the standard crankshaft dude
#112
I have a question to fellow owner of this engine...
I just finished breaking my engine in, and checked the head clearance, it was 88mm, yes that is correct.... out of the box... My question on 25% nitro
should I set it in the 50mm to 60mm ranage?
I thought these motors came from the fatory setup to run on 16% nitro.
Let me know what you guys are seeing...
#113
WOW!!! My whole tz will fit in an 88mm space!
#114
So what is the correct head clearance I should be running at?
To get down to 53mm, I only need a single 10mm shim... Something just does not seem correct...
#115
I have never checked the clearence on mines, but will do as soon as I re-assemble it. (Took it down to check it over)
I have been using 25% on mines and to be honest, I am not totally impressed with the performance. I have been testing different pipes and found a combination pipe / header that seems to perform the best but it's still not mind blowing.
I should say that on taking down the engine I noticed 2 shims, whereas my 5P came with one.
Once I double check the clearence I may remove a shim. Are you saying that 50-60mm is safe for 25%?
#116
2. Based on head clearance, choose your nitro %:
16% Nitro .36mm - .40mm
20% Nitro .40mm - .50mm
25% Nitro .50mm - .60mm
30% Nitro .60mm - .65mm
As far as the performance, I have agree results... Even better with proper Clutch setup and the OS 1040 pipe.
#117
per a post on here, but I'm not sure of the link:
What other pipes have you tested?
Also, you used solder wire to check the head clearence?
#119
From Japanese magazine "RC World" knew that OS have new product, OS TZ12 Speed version 2 (low CG), same listing price with Speed!
#120
Perhaps a photo or page link?
Thanks.
