Old 03-20-2007, 08:09 PM   #1006
Hi guys, I need some help with my clutch set-up. Iím going to install my Orion CRF Wasp Rev (1st version) / Orion CRF 2626 pipe and header on my G4S (stock) using the Orion Clutch Setup for G4S. I need some inputs on (a) clutch spring preload (b) end play (c) clutch gap (d) how many set screws to install on weight.
And also for those G4S guys using this combo, do I need to replace any of the pullies and what pinion/spur shall I use to make this engine rev?
Below are pictures of our new track (if these helps...)
Thanks in advance guys!
OrAnGe PoWeR
Team Orion CRF Wasp Rev X-Dyno results-1.jpg   Team Orion CRF Wasp Rev X-Dyno results-2.jpg   Team Orion CRF Wasp Rev X-Dyno results-3.jpg
OrAnGe PoWeR is offline   Reply With Quote
Old 03-21-2007, 10:00 AM   #1007
OleC's Avatar
Thanks Ziggy:-)
We have borrowed a Serpent flywheel and parts so we can put together a complete Orion conversion kit on our GPX4.
Will test this afternoon.
BTW, how do people measure the spring preload? I have seen measurements from top of the threads to top of spring collar. And also from bottom of spring collar to top of clutch shoe.
I see some say preeload of less than 1mm, but also more than 2mm...
During testing yesterday we had some problems with high revs after throttle input.
OleC is offline   Reply With Quote
Old 03-21-2007, 10:40 AM   #1008
ziggy12345's Avatar
All depends on the distance the flywheel is away from the crankcase after installation. The cones that locate the flywheel are all different sizes and you cant measure the distance from the top of the nut to the spring collar as this will vary due to the flywheel gap.
Set it at 0.8 mm and keep tightening it until it engages too late and then loosen 1/4 turn
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 03-21-2007, 12:49 PM   #1009
razzor's Avatar
OrAnGe PoWeR
This is just some advice from what we have experienced with the CRF.
On the G4S id say .5/.6mm clutch gap and all the weights or at least 1 weight, endplay .1mm.
Preload is a touchy setting and id advise starting at 1mm with a black 1.8mm clutch spring.make adjustments of 1/4 turn untill it slips a bit and then back off 1/4 turn.
Gearing would depend on if you running std transmission gearing or ED.
std gearing id suggest 18t brake and side pulley and 18t 1st gear pinion ,if running ED run 15t or 16t 1st gear pinion.
ED is the way to go for the CRF though and would make the engine come alive both for bottom performance and top speed.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-22-2007, 04:37 AM   #1010
Thanks razzor! Have you tried the orion clutch setup with square springs? the ED transmission is next on my list, but this will do for now.. i've ordered 18t brake and 18t brake side to gear down the car but will still be using 26 front side with 2mm tire split. Can't wait...
Thanks..
OrAnGe PoWeR
Old 03-22-2007, 05:30 AM   #1011
Z00M's Avatar
Trader Rating: 15 (100%+)
Nano, I sent you a PM. Hope you get a chance to look at it.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 03-22-2007, 09:55 AM   #1012
OleC's Avatar
We did some more testing yesterday with the serpent flywheel an Orions Serpent conversion kit on our Hobao. Also geared it down a bit for our tight track.
Man, did it come alive!!!!
Further testing is done today with the Orion pipe kit (2626).
We used all the weights, 0,5 gap, about 1,8mm preload (shimmed the flywheel nut so that the spring starts to compress when the back of the nut is flush with the top of the threads), and about 0,05mm endplay.
Leaned the HSN quite a bit. LSN was made richer than factory settings.
Air temp is about 4-5C (freezing! )
Running MECCAMO touring competition fuel: 16% nitro, 8% oil.
Big thanks to Nano for helping us understand this engine better and bring out its potential!!
Old 03-22-2007, 10:48 AM   #1013
teammpp's Avatar
Not sure I am following you here Ziggy. The nut tightens against the flywheel. If the flywheel was 1mm out from the crankcase and you then put another 5mm spacer in then would the nut also not move outwards 5mm????
Therefore you can always measure from the end of the nut to the spring collar as this part of the setup remains constant regardless the position of the flywheel from the crankcase.
teammpp is offline   Reply With Quote
Old 03-22-2007, 11:02 AM   #1014
ziggy12345's Avatar
Yeah your right... I was thinking of the clutch gap shimming which does alter if the flywheel is out more as the thrust bearing retainer screws onto the crankcase.
My mistake
Sponsored by:
Norfolk and Chance
Old 03-23-2007, 05:40 AM   #1015
OleC's Avatar
We put shims under the flywheel nut, to have the spring just starting to compress as the back of the nut is flush with the top of the nut (threads) and that worked out nicely.
Not sure how everybody else does it, but with this method we should all be able to compare and try the settings that people post.
Old 03-23-2007, 09:04 AM   #1016
Schrijver99's Avatar
Does anybody what the difference is between the CRF Wasp Rev 12 Cyrul spec and the CRF Wasp Rev 12 2007?
Schrijver99 is offline   Reply With Quote
Old 03-23-2007, 09:55 AM   #1017
ziggy12345's Avatar
Where have you seen that one?
Cheers
Sponsored by:
Norfolk and Chance
Old 03-23-2007, 10:02 AM   #1018
I have just received a few nos of CRF2007, ORI80600 from my local distributor.
Almost everything is the same as Cyrul spec. except the cylinder is different.
It has more torque and better top speed than the older version.
RC Synergy is offline   Reply With Quote
Old 03-23-2007, 11:43 AM   #1019
asil's Avatar
Send a message via MSN to asil
As quoted from team orion catalogue, differences over ORI80600 CRF Wasp Rev 12 type 2007;
ORI80601 CRF Wasp Rev 12 Team 2007 Pro Tuned Limited Edition;
- CRF Swiss made modified CNC cut back plate
- CRF CNC cut combustion chamber
- CRF pro venturi
Asil
asil is offline   Reply With Quote
Old 03-23-2007, 04:38 PM   #1020
Those are the 2007 and the 2007 pro tuned.
But what is the difference between the CRF Wasp Rev 12 Cyrul spec and the CRF Wasp Rev 12 2007?
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
