Looking for a new engine..
Old 08-01-2019 | 09:23 AM
sinisterRC's Avatar
Default Looking for a new engine..
Hello,
I currently have a Nova Rossi .21 Flash in my MRX6. Looking for a change, A few guys in my track run the OS RP9S .21, sounds like a beast and is very fast. Problem is it's out of stock. I was also looking at the Ielasi Tuned Raptor .21. Any input will be appreciated!
Thanks,
sinisterRC is offline
Old 08-01-2019 | 09:52 AM
1/8 IC Fan's Avatar
OS rp9??? Try the regular R21 its a great OS motor without the DLC or ceramic bearings. Otherwise any of the R series are great R2101-2103.
The RP9S is a Max Power Motor. Not same as OS Max.
1/8 IC Fan is offline
Old 08-01-2019 | 09:54 AM
BigC2007's Avatar
Just picked up a Novarossi Mito .21 9-Port On-Road Engine (Tuned) (Steel) "Limited Edition" and running it in my MRX6R its a powerhouse and fast you can pick them up for $233.00 shipped on the bay.
BigC2007 is offline
Old 08-01-2019 | 09:56 AM
~McSmooth~'s Avatar
I see that you're in Miami, and assume that Homestead is your home track.
With that long of a straightaway, definitely something with some legs - a 9 port.
~McSmooth~ is offline
Old 08-01-2019 | 10:01 AM
sinisterRC's Avatar
Yessir, looking for a little more power. The Flash .21 is a 9 port but seems to lack a bit of power.
Old 08-01-2019 | 10:03 AM
sinisterRC's Avatar
Thanks for the info on the RP9S, didn't know that.
I also like the R2103, but the specs are very close to those of the Flash .21 I currently have.
Old 08-01-2019 | 10:06 AM
BigC2007's Avatar
I used to have a flash also it was decent in power but also they are an older motor, how many gallons you have through it ? Mine started losing power around the 3 gallon mark. Also what pipe are you running ?
BigC2007 is offline
Old 08-01-2019 | 10:17 AM
sinisterRC's Avatar
I have about 2 gallons through it. 2015 Pipe & 41016 medium manifold.
Old 08-03-2019 | 05:23 AM
Pooh2's Avatar
OS 2103 or OS Euro spec. Easy to tune and very fast. Nova's hold their own and there is nothing wrong with them at all. I ran them since 95. I just change 2 seasons ago. My advice, get something up to date and stay away from ceramic bearings. They work but only if you really know what you are doing with Clutch and engine tunning.
Pooh2 is offline
