-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   Axial Engines thread (https://www.rctech.net/forum/onroad-nitro-engine-zone/103940-axial-engines-thread.html)
XTREMERCHOBBIES 07-22-2006 09:01 AM
Any break in suggestions for the Axial .12RR? Which pipe will bring out the power of this engine? Any help is appreciated :)
kitracer 07-23-2006 05:48 AM
Break in procedure. ( this may be your easiest break in ever :nod: )
Idle 30 sec then put on track for 3 tank @ medium speed. let it cool, check compression, sometimes it may be ready for race tune. Then 3 more tanks with short interval of full throttle, then engine ready for race tune.
At all time, just make sure pretty of smoke, Temp 80 to 100 for breaking in. Race tune up to 120C for hot asia condition.
From torque to top speed
Novarossi 2601 (middle size 6 fins manifold)
JP 2620
HA Optimized 2613 ( or Mugen 2613)
Novarossi 2615 Turbo ( with 6 fins manifold)
XTREMERCHOBBIES 07-23-2006 06:52 AM
Thanks Chris! I am using the RB EFRA Pipe with short conical manifold, you think this will do? Please send me axial sticker :nod: Let you know as soon as I get the engines...
tl2111 07-23-2006 07:54 PM
Edward, your PM is full
4racer 07-24-2006 12:06 AM
hi chris,
what for a manifold did you take for the ha 2613, the kit one, ore another???
witch total head clearence ist the best for 16% nitro.
dieter
kitracer 07-24-2006 05:11 AM
Originally Posted by 4racer
hi chris,
dieter
I used manifold come with the Kit. ( did they have different size, I would like to try a longer one if available)
I suggest going 0.3mm head shim first, then 0.25 I think is the lowest you can use. Sorry I have not measure the total head clearance on this engine yet.
What Plug were you using Dieter?
I tested back to back yesterday with JP 2620 and HA 2613 pipe. The HA have more Topend but JP 2620 have better torque.
My setting yesterday (but I feel I can still get bit more out of the Axial)
25% Tornado, Air Temp 36C, Humidity 80%
0.4mm head shim with JP 2620, standard Manifold
0.35mm head shim with HA 2613
kitracer 07-24-2006 05:15 AM
Somehow, I dont like to use a short manifold on this engine. I tried the MAX and Novarossi, both short manifold and they dont work at all on this engine.
I dont have item number off my head but the number ends with "C "
XTREMERCHOBBIES 07-24-2006 05:21 AM
Kitracer - By the way, did you send my engines to my broker? Hope to get it soon:)
kitracer 07-24-2006 05:27 AM
I sent the email reply to you already :D
XTREMERCHOBBIES 07-24-2006 05:41 AM
Thanks Chris I got it! Lets keep this thread alive, will share my experience with this engine and tuning suggestions.
4racer 07-24-2006 06:10 AM
hi chris,
yes the have longer manifold, the ha pipe ist with the kit manifold in my eyes a very short pipe, and works well with engines with a great outlethigh.
i use odonnell odo 97t or odo 99t when it is hot.
i have measured many engines and there are big differences in total head clearerence.
dieter
kitracer 07-24-2006 06:38 AM
hi chris,
dieter
how can I find the longer manifold? I bought my set from Geoff from UK.
97 or even 99... thats too much. I suggest 77 odonnel if you using 16%.
YBSLOW 07-25-2006 07:39 AM
Message
Edward N,
you have PM.
L8R!
Brad
4racer 07-25-2006 08:20 AM
hi chris,
i buy it from manufactor,
if you interested give me a mail :sneaky:
ok i will test with odo77
dieter
YBSLOW 07-25-2006 01:48 PM
Originally Posted by YBSLOW
Edward N,
you have PM.
L8R!
Brad
Ugh. your mailbox is full?
