Picco bost 21 5t-r
Picco bost 21 5t-r
I Just picked up a brand new Picco Boost 21 5T-R Team spec engine. It came with two venturi inserts for the carb a 7mm and a 6mm insert. Which one do you run normally and also I am going to be running 30% nitro in this engine do I need another cooper O-Ring to run this fuel?
Thank You
Michael Johnston
Thank You
Michael Johnston
Thank You
Michael Johnston
Thank You
Michael Johnston
7mm for medium to large tracks
It's shimming for 25%-30% from the factory.
If you are using a new pipe, it's recommended to clean it with break cleaner before using.
Thank You
Michael Johnston
Thank You
Michael Johnston
