Picco bost 21 5t-r
Old 04-14-2017, 07:06 PM
Default Picco bost 21 5t-r
I Just picked up a brand new Picco Boost 21 5T-R Team spec engine. It came with two venturi inserts for the carb a 7mm and a 6mm insert. Which one do you run normally and also I am going to be running 30% nitro in this engine do I need another cooper O-Ring to run this fuel?
Thank You
Michael Johnston
stoney452 is offline
Old 04-14-2017, 09:39 PM
Thank You
Michael Johnston
6mm for small tracks
7mm for medium to large tracks
It's shimming for 25%-30% from the factory.
If you are using a new pipe, it's recommended to clean it with break cleaner before using.
Talsys is offline
Old 04-15-2017, 02:11 AM
Thank You
Michael Johnston
What pipe are you using on your picco 5TR
WavyEnzo is offline
Old 04-15-2017, 10:05 AM
2099
Talsys is offline
Old 04-15-2017, 05:16 PM
I have a good Jp 4 that will go with this well
Michael
