O.S. SPEED .21 XZ-B SPEC. III
#226
I have a brand new 2050 w header
#227
Has anyone tried the 22c carb on the Spec 3 Motor?
Thank you
Thank you
#229
The 22C will be a little smoother and slightly less overall power, but it will increase runtime.
#230
Spec 3 rod
Does anyone know who has a connecting rod for the spec 3 in stock? Ice done some research and found that the spec 3 uses the same rod as the b2101/b2102 so I assume it would also use the same rod as the ninja bo3 correct? And what if any are the differences between the original speed xzb,spec 2 and spec 3 rods.im looming to possibly replace mine after breakin or just to have on as back up but nobody has them in stock til August that I've found.as always thanks a lot fellas.
#231
#232
I've had quiet a few speeds over the years, looking at 4 right now! Only time i ever replaced a rod was when the motor got a new sleeve and piston too! Never broke one!
#233
Ok thanks.my spec 3 has a slight amount of movement between the crankpin and rod when I opened the backplate when brand new and of course after 7 tanks of breakin now it just is worrying me.i know it's got to have a very small amount of wobble,if u will, to allow lubrication.thats why I was trying to locate a rod.
#234
#235
Finished breakin and good Lord why didn't I just get a speed from the get go.love my novas but this engine has some balls and I believe I'm at about 75-80% tuned.what differences are there as far as tuning between the novarossi and speed engines.thanks again for the replays gents
#236
#237
New to os engines so forgive me. Have a spec 3 in truggy. Ran great all through quals. During main it shut off twice at the end of the long straight. Just as I went from full lit to some break. Motor doesn't seem lean. Is my lsn too lean?
#239
#240
Little bit of tuning help
Got a quick question.this is my first speed and I'm used to novas and leaning out the lsn a food ways then going to the Hsn.is this kind of the same procedure for the speeds or is it a little different? I'm finding that I can't really get the engine to clear out until I really crank down on the Hsn.Any tuning advice is much appreciated.its in an mbx7tr,p3 plug,byrons 30/11,m2c 4 shoe clutch w/1.0mm springs if ya need that info.thanks alot.
