ATOM engines thread
#106
#109
Anyone run this in a truggy? What are you using or would you recommend for a pipe?
#110
An OS 2090 or Nova 9901 work best. A 2058 or Atom pipe will work in truggy if bottom is all you need. With any of those pipes, use a long header for truggy, it creates way more bottom on this engine. I used a Nova 41020 on my truggy with both nova and os pipes. The OS was a little better I think but they were close.
#111
#112
#115
Top: 1.5 turns out from all the way in
Bottom: Flush
Mid: 1/2-1 turn out from flush
Check the mid range first. On some of the carbs, it cuts off the fuel supply too much running the needle flush, then causing a rich bottom end setting.. To check it, remove the top needle assembly and look down at the holes in the mid range. Set so the holes line up and tune from there.
#116
Stock setting:
Bottom: Flush
Bottom: Flush
#119
thanks gene. My son was given a brand new 1 that was broke in by adam drake and a almost new 1. I ran about 6 tanks out front of my house and slowly brought it up to race tune about the 5th tank. Then we went and he raced all day no issues. I just noticed that if you go an hour or so too rich on the bottom it would give a slight lean bog when trying to be snappy. Im pretty sure everything but the mid range is in the stock setting area. The mid range is flush.
#120
I would like to know if you still had any Atom SV-1R engines for sale "New, Used or in parts ". Please let me know.
Thanks a million
Thanks a million
