Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Problem during break-in - can't get fuel to carb >
Old 05-21-2013 | 02:05 PM
Default Problem during break-in - can't get fuel to carb
Hi,
So I'm having a bit of a problem breaking in a Dynamite .21 Mach 2 engine.
First I pre-heat the engine to about 100*C, then plug the exhaust and start running the car on the starter box to bring fuel to the carb.
I can see the fuel (mixed with a couple of huge air bobbles) slowly traveling along the fuel line from the tank to the carb, but as soon as the fuel reaches the carb nipple it immediately retreats about 3-4 cm (2 inch) back down the fuel line.
And so it continues, with me alternating between plugging the stinger to get the fuel going and holding the igniter to get the engine going, until suddenly, after about 10-15 minutes of this "procedure", the engine fires and runs.
And then it will run just fine for the intended 3 minutes until I shut it down, wait for it to cool down, and it's time to try to start it again... and we're back to square one.
I completely drained the starter box battery (4S 3300 MAh) and glow igniter (1800MAh) managing only three rounds of break-in!
Along the way I have shortened the fuel/pressure lines to an absolute minimum, I have swapped in new fuel/pressure lines a couple of times and I have swapped in an old tank I had laying around. None of these things helped. There are several huge air bobbles in the fuel line and this strange "retreating effect" when the fuel is just about to reach the carb. And then suddenly the engine runs just fine?!
Has anyone got an idea what's going on? Thanks!
jackinabox is offline
Old 05-21-2013 | 02:17 PM
Hold the throttle open with the radio pull line off of the exhaust and blow in it to get fuel in motor
evolution03 is offline
Old 05-21-2013 | 04:10 PM
Jaz240's Avatar
I think you are heating the carb and the fuel is burning up before it enters the engine. Keep the heat away from the carb even if you have to block it off with something.
Jaz240 is offline
Old 05-21-2013 | 08:08 PM
RCmayor's Avatar
Open the idle needle (low mixture) about a turn. It sounds like the fuel is getting to the carb and cant go anywhere because the needle is closed fully. It's possible there is a problem with the Upper needle being blocked. Maybe a chunk of something is floating around the carb inlet.
RCmayor is offline
Old 05-22-2013 | 03:51 AM
banana rt's Avatar
- make sure your starter box turns CLOCKWISE (so that ur engine turn COUNTERCLOCKWISE)
- Clean ur pipe, the pressure nipples usually clogged, blow out with compressor.
-check ur fuel tank if its clog too
- check ur glowplugs
Hope will helps
banana rt is offline
