Engine leaking nitro, need help
I noticed some fuel on my receiver box, so I took a close look when running the engine. It seems like fuel is spitting from between the cooling head and crankcase... how do I fix this?
It could also be coming from the exhaust gasket, although it is new, I'm going to get a different one sometime this week to check. But if it is in fact b/w the cooling head and crankcase, I'm not sure what to do.
My idle seems to be a bit erratic and so does the tune, w/ a leak this is the most likely cause, correct?
I'm running a LRP .28 w/ Byron's 20%
If the head bolts are tight then look at the exhaust. Just because the gasket is new doesn't mean that it didn't get a tear in it or that the manifold is on straight. Could be cocked sideways or the gasket tore on re installation. If the leak is between the head and case you have a major issue. Take the head off and check the shims to make sure they haven't been cracked or bent or not installed at all. And that the head is on straight use a star pattern(like putting a 4 lug tire wheel) to tighten it down.
Has this engine been disassembled before? The shims may be aluminum in color and hard to recognize.
http://aedownloads.com/downloads/man...28R_manual.pdf
Pics
Ok, I took off the head and button and the shim was there, looked ok to me. The head of the piston looked "burnt" a little but seemed ok also (no scarring etc, along w/ the sleeve, looked clean.
One screw seemed a tad tight and upon further review didn't look like it screwed all the way down. I swapped it out w/ a new screw and it screwed in nicely.
I'm putting it back together and getting some new gaskets for the manifold and we'll see what happens.
Please look at the pics and let me know if something looks wrong to you.
