Pipe for EB Mods VSpec?
Old 03-15-2012 | 06:59 PM
killabud's Avatar
Default Pipe for EB Mods VSpec?
Hey Guys, I have an EBMods Full mod Vspec here that Im putting in my truggy. What pipe would you go with?
Im thinking any of these will work just fine but cant pick!
OS2050 / Losi RE11
OS2060 / Losi RE10
EBMods pipe / 2041 (if I can find one, doubt it though)
Ninja 2042
killabud is offline
Old 03-15-2012 | 07:02 PM
Suspended
i would go with the 2060, or jp-2 or jp3. ive also have good results with the odonnell v2 pipe
D-MAIN is offline
Old 03-15-2012 | 07:03 PM
Jerm13's Avatar
Allways had good luck with my JP-1's when I used V-Specs. If that isnt an option, i would go with a low end pipe like the OS 2050 or RE10.
Jerm13 is offline
Old 03-15-2012 | 07:05 PM
killabud's Avatar
Yeah I was thinking 2060, I have the JP pipes but they seem to kill MPG big time on any engine.
killabud is offline
Old 03-15-2012 | 07:14 PM
Suspended
thats the only bad thing with the jp pipes, i would try to find a cheap odonnell v2 pipe and see how you like it, you may be suprised. i run one on my v-spec and it rips
D-MAIN is offline
Old 03-15-2012 | 07:23 PM
2060 or 2035 reedy pipe. I prefered the reedy pipe in the truggy. Still get good runs times and has a bit more bottom end
Flip it is offline
Old 03-15-2012 | 09:01 PM
ehames005's Avatar
R/C Tech Elite Member
The 2041 would be the best pipe for your engine. You can find them around you just have to look. Also the Reckward 2041 is the same as the EBmods pipe.
ehames005 is offline
Old 03-15-2012 | 09:06 PM
trevinator's Avatar
Ditto what he said. I run this on a modded vspec and a Speed. Great power and mileage.
trevinator is offline
Old 03-15-2012 | 09:08 PM
jmaxey51's Avatar
OD R2 only pipe they made.
jmaxey51 is offline
Old 03-15-2012 | 09:10 PM
Suspended
right, and works excellent with the OS engines
D-MAIN is offline
Old 03-15-2012 | 09:50 PM
I have one of eds modded vspecs and it came with a printout of pipes he dynoed and recommended ! Nova 9853, jp3, and of course the 2041 ! I would go with the jp3 or 2041 myself if Ur putting it in truggy !
travertini is offline
Old 03-16-2012 | 11:39 AM
I'm running a 2060 on my frankenspec (vzb with ninja crank, speed rod, eb mods head button) and it just rips in my buggy. Enough bottom to wheelie if the front becomes unweighted, and screams down the straight. I was running a jp3 previously, and although it had great power, the poor mileage just wasn't worth it. + 1 on the 2060
ewing61 is offline
Old 03-17-2012 | 09:24 AM
joey91473's Avatar
I have the same engine and I was running the JP-1 (killed runtime but screamed) and ended up using the RE11 pipe. Liked it alot.
joey91473 is offline
Old 03-17-2012 | 12:37 PM
killabud's Avatar
Thanks guys, I think I'm just gonna go with a 2060. I hqve that and a 053 to try anyway.
killabud is offline
