force .28 shims???
force .28 shims???
How many should be on the motor from factory and or how many should i go with??
thanks
thanks
It should have two of the .02 shims.
What if I just run it with 1?
I gotta check what I'm running now? Will one less shim make a diff?
It will raise the compression. Running a higher % fuel may cause damage.
What percent should I run?
Is it work removing a shim and runnimg lower fuel compare to just having higher fuel?
It should work. Just double check the clearance isn't an issue. Fewer shims wil basically produce more torque, and more shims will enhance the top end.
what % should i run with 1 shim?
i have 30% percent currently...
Im running 30% with a ofna picco #6 med. Please advise if my setup is correct or if i should move to a hot plug. Also, if i remove a shim what plug should i use?
thanks
thanks
lol. i would leave it at stock, forces dont last long anyway
ok i removed head and there is only 1 shim installed im running 30% right now. Should i drop down to 20% when the gallon is done?
