JS Racing Engines
#151
Has anyone tried running the js with a 2058 pipe?
#155
We are expecting them towards the end of april in the USA. I just received the new carburetor and other parts to test out and the carburetor is a big improvement to the old one. The slide is nice and smooth, long LSN needle. It should work great
Yes, they are made as the same factory as many other engines
#157
Anyone run the Go 2072 pipe on the JS?
Do also have an RE11, APLUS, O.S 2060 AND 2090, and a werks 2013 pipe I could try if you think better option?
Cheers.
Cheers.
#158
Ive tried 2060 2058 and 086.imo the 086 gv the best all round power and mileage.
#160
Oh I dont have any of those pipes ..have put the Go pipe on for now and will see how it goes
#162
when does the new 2012 model come out? any idea on the price?
#164
question? i'm now going to run this engine in a mugen and hopefully it stays there[found a home]. if approaching a jump with full throttle, then let off throttle before the peak of the jump, and in mid flight the engine still screams a high pitch sound[ many rpms], which set screw is to lean? high end or low end? the slide valve returns all the way back to the idle stop very quickly when let off full throttle. the throttle servo is making a little noise at idle position. servo jr high voltage. expensive
#165
Erik
