Please sugest good Temperature meter .
Please sugest me a good temperature meter for help in engine tuning.
Thanks.
Mario.
Thanks.
Mario.
Yes, thatīs the one.
I knew from old times, was diferent shape, always did cost alot, but consistent readings.
Thanks.
Thanks.
http://www.amainhobbies.com/product_...Gun-Tempguncom
Cheap and to the point. Yes the big $$$ temp gun will most likely be more accrurate but you shouldn't be relying on temp. that much anyway.
This is the one I have and i've checked it against someone at the track I run that has a high doller gun and i'm within 5*F. Good enough.
Get the only one worth buying. Temp gun is a very important tool.
Tune my sound, feel, and smoke and you actually will not need a temp gun. I use a 20 buck one after my mains just to see if it's not crazy hot.
anybody who has been in the hobby a while will let you know temp guns are not for tuning, fastest way to e conversions. tune in small increments from rich to lean and find your "window". stay on the rich side of the window as much as possible and only temp motor if its in the window then all of a sudden acts funny. if you tune in small increments you will get to know your motor a lot faster to the point where you will be able to tell your pit guy "3 or 4 hours on top" and get it spot on every time.
I think the only time I use a temp gun is when I am breaking in a motor. Other than that I tune to smoke, sound, and response. After a race I will do a "spit test" just to make sure the engine isn't cooking.
absolutely the best....
http://www.mechanicstoolsupply.com/b...UVB/index.html
shop around for maybe a better price.
