os speed shimming ??
Old 12-29-2010 | 11:36 AM
addicted427's Avatar
Default os speed shimming ??
I HAVE AN OLDER MODEL SPEED ENGINE AND WANTED TO KNOW THE THINKNESS OF THE SHIM NEEDED TO RUN 25% NITRO...
addicted427 is offline
Old 12-29-2010 | 11:59 AM
EBMods's Avatar
For the older OS engines they should have a total of 0.012" / 0.3mm worth of shims. Giving you a NET head clearance of 0.016" / 0.4mm. With this shimming your good for 30% Race Fuel with 7%-11% oil content in the USA.
EBMods is offline
gabor szilagyi's Avatar
Same imfo...
gabor szilagyi is offline
Old 12-29-2010 | 01:31 PM
I'm running 25% Byrons. Not 30
Old 12-29-2010 | 01:32 PM
EBMods's Avatar
Your good for 25%
EBMods is offline
Old 12-29-2010 | 01:52 PM
What would be the diff of running 0.010 and 0.015 shim
Just trying to learn a bit.
Old 12-29-2010 | 03:10 PM
With less shim (thinner shim) you will have more compression ,more pressure on conrod,maybe a little more chance to blow the glow plug ,however 0.05mm diff not too significant...The way how we do here (with 25%-30 nitro) we leave the 2 copper shims with the alu shims during the brake in and about 1 gallon we remove one of the copper shim....
Old 12-29-2010 | 03:27 PM
EBMods's Avatar
If you can please be more specific about your question.
EBMods is offline
