.21 engine problems
so heres the problem. i fire up my buggy, and it idles perfectly, not a hiccup. i tap the throttle, it revs up fine, but once i hit the throttle with a little more bite, when i let off, it just cuts the engine. i thought it was running lean because of the weather, plus its cold, so i richened it up alot, same issue.
Originally Posted by Crazycajun322
(Post 8284318)
thats what i thought at first too, but i stuck the glow starter back in after it sat for a minute, and it fired right back up. i must've done this 20 times while fooling with the needles
(Post 8284351)
(Post 8284351)
its just a standard ofna 3 shoe. never had any problems like this. Granted, my buggy was sitting on a shelf for about a month and a half, so anything could've happened to th car, but before i started it again, i took the engine apart and gave it a thorough cleaning.
Originally Posted by inferno13
(Post 8284382)
try leaving the glow ignighter on it when you run it
(Post 8284394)
ya ill try that, but it just got dark, and its about 35 degrees outside, so i might just wait till tomorrow
(Post 8284444)
i bet if you leave the ignighter on it will run perfect, just because the plug lights up and starts the engine does not mean its good, either plug is bad or you need a hotter plug.;)
Check the clutch/bearings as well.
turns out it was the plug. runs good now, although its bitter cold outside so its been acting up a little bit, but nothing out of the ordinary
(Post 8289439)
| All times are GMT -7. It is currently 03:35 PM. |
