Losi 454 engine
Losi 454 engine
There are a lot of 8t 2.0 RTRs out there, and I wanted to start a thread for the 454 .28 engine. Just to share tips, tricks, advice, and experiences about the 454.
Ill start with a question-Does anyone know of a shorter carb arm that will fit on the 454?
Engine performed great this Sunday. I was able to get over 10mins on 1 tank!
I know this is not the norm but I run on a very small track, so I can get better mileage.
A lot of people say the turbo head does not make a big difference on this engine but I noticed a much more explosive engine through out the power band. Right now, I am also running the re-11 pipe and it is working out pretty good however I do think it restricts the top some.
Here is a vid of it running:
http://www.youtube.com/watch?v=Ie8v242zc2Y
Well my sons 454 throw a peice of the rear brearing taking out the p/s. We had 4 gallons on it and the motor was still running awesome. My bad for not changing it sooner. I am sure it still had a ton of life in it. I could never get 10min out of it even with a sportworks carb with a 7.5mm insert. I think the best we ever got was 9min. The motor makes huge power and is one of the fastest motors I had but at the same time was hard to drive smooth (for my son to drive smooth)
For a rtr it is a outstanding motor and I will grab another one soon to have as a practice/bash motor. We ran ours with the turbo head/sportworks carb and a orion 2013 pipe running 14/50 gear ratio.
sein I also tried the re11 for a bit and it felt good but rob the motor of low,mid and high end. try a re10 or a 2013 it will really wake that motor up.
Suspended
why a shorter carb link?
I have a re-10 I will try soon; but I have a race coming up next Sunday, so I will keep setup the same until after.
If one of you guys are intrested in the sportworks carb let me know, you can have it for free just pay the shipping.
no prob, if anyone else wants it please just pm and and it is yours. It is a exact copy of the losi carb (i even used all the needles from the losi carb) but takes inserts, I have a 7.5mm in it now.
The stock 454 carb has a 9.5mm bore which is huge and part of the reason they are so bad on fuel.
I'm almost ready to give-up on Losi engines but will give it one more try. Bought a Losi350 brand new for my 8T and it threw a rear bearing ball which destroyed piston and sleeve (about 3/4 through break-in). Put my older R21 in it and it runs fine.
Bought a brand new Losi454 for my 8T and cannot get it tuned. I've tried everything. Warm engine up before starting it - no change. Running for 1-2 minutes between each tiniest adjustment - no change. The thing would rich to a point where it wouldn't even launch and then 2-3 min into sputtering around it would lean up to a point where it would idle in that high-pitch bouncing idle. Went back to factory settings and started all over - but no luck.
Tried to remove the carb to put another carb in it and it was stuck/seized to a point where i had to heat up the case to get it moving. After endless struggles i got it out but the shaft broke in two pieces, meaning the upper o-ring came out with the carb but the lower o-ring remained in the engine together with a piece of the shaft.
Got it all out now.
So, one last chance for the 454 before i order a Triton from Lance: what carb should i put in? I measured 14mm shaft diameter on the original carb. Had some novarossi carbs flying around but they are larger in diameter and won't fit into the 454 crank case.
I'm not a racer and don't need max power. I just want the thing to run OK, just like my other nitros that i got tuned in just fine. Don't care about run-time or anything.
Thanks.
Got it all out now.
Thanks.
I dont recall what carbs swap; likely any SH mfg.
Your Triton option will likely make you the happiest long term
