-   Offroad Nitro Engine Forum (https://www.rctech.net/forum/offroad-nitro-engine-forum-157/)
-   -   Modd head button (https://www.rctech.net/forum/offroad-nitro-engine-forum/445894-modd-head-button.html)
sluggo_sx8 10-23-2010 07:25 AM
Originally Posted by wingracer (Post 8111527)
http://somender-singh.com/content/view/68/49/
Most of these are real car and go kart heads but there are a few of a single groove RC head.
coool thanks
Roelof 10-23-2010 08:48 AM
Like this (original -> modded)
http://www.mbcfriesland.nl/wp-conten...lphabutton.jpg
Maximo 10-23-2010 09:02 AM
I will do some testing today, and post my results back this evening....Should be pretty interesting !
jpalessi 10-23-2010 09:08 AM
I would think you'd have to readjust the head.
Roelof 10-23-2010 09:19 AM
If you do the 3-groove mod, maybe also an idea to rotate the button head 180 degrees to see if it has some influence.
houston 10-23-2010 10:20 AM
I've seen it done , I've played with it , it definitely works but needs to be scaled down to our engine size.
Fyi , it works better done just inside the actual combustion chamber part of the head button ;)
Reason its not widely used in our engines (micromotor nitro) is it has an inconsistant power delivery and odd power band transfers .
Pluses are increased fuel and max rpm gains along woth cooler running temps
dayglo33 10-23-2010 11:59 AM
Houston, when you say inconsistant power delivery, are you saying the motor flames out alot or stumbles at low rpm sometimes or what? How many cuts did you use? How deep were the cuts? Were the run times noticly better? How much cooler? Any input is very apperciated.
houston 10-23-2010 12:15 PM
i am talking fluctuations in power delivery , like spikes in certain rpm and dips in other
runtimes on average were probably 20% better , temps i would say about 15-25% cooler ( depended on engine design ) , tried several three cut methods and the one that had the most consistency and gains in all areas was the .25mm deep cuts inside the combustion chamber of the head button in counter clckwise fashion (pics needed to explain fully ;)
jbright33 10-23-2010 12:30 PM
interesting
dayglo33 10-23-2010 01:08 PM
Now you know i'm going to ask for a picture! Are you saying that you put the cuts closer to the glow plug when you say you put the cuts in the combustion chamber? Are they angled then too?
The spikes and drops were on a dyno I take it? Did you run the motor in a truggy or buggy?
jbright33 10-24-2010 05:39 PM
hmm what happend i was watching this thread was very interested in it. neal did you do any testing?
Roelof 10-26-2010 11:04 AM
Did you manage to do some testing?
Maximo 10-26-2010 11:36 AM
I am going to right away...I had to put together a dyno mule to test with...Alll I had broken in and ready to roll were some pricey engines ...So I didn't want to experiment with anything too expensive
rotarynut 10-26-2010 06:10 PM
Somender Singh
For those of you that want to do some reading into this subject, it explains what it does and how it's acomplished. Very interesting...seems that he got he ROYAL blow off from the big companies,why?...'cause they didn't think of it first.:sneaky:
http://www.rexresearch.com/singh/singh.htm
houston 10-26-2010 08:05 PM
that was a good half hour of reading , although a few sections were just reiterations of previous sections there was some great info and i feel inspired to do a little more testing :D
