colder weather tuning...
Old 10-15-2010, 07:53 PM
alexrckid's Avatar
Default colder weather tuning...
when the temps start dropping, do you run the HS a bit richer or leaner...???
alexrckid is offline
Old 10-15-2010, 07:59 PM
tmaxx26power's Avatar
Trader Rating: 39 (100%+)
richen it up
tmaxx26power is offline
Old 10-15-2010, 08:25 PM
Toiffel's Avatar
Trader Rating: 52 (100%+)
Originally Posted by tmaxx26power View Post
richen it up
+1 and hotter plug.....
Toiffel is offline
Old 10-15-2010, 09:03 PM
boomgagem's Avatar
Trader Rating: 45 (100%+)
Yep, cold weather is normally accompanied by low humidty. So there is not as much moisture in the air. Fatten her up!
boomgagem is offline
Old 10-15-2010, 09:05 PM
Run richer and you can add aluminum foil around few fins to make sure it goes up in temp.
You can also read this http://www.myrcbox.com/?p=3899 this explains engine tuning according to weather.
Sylvain is offline
Old 10-15-2010, 09:34 PM
Trader Rating: 10 (92%+)
When running in cold weather i take an old sock and wrap the fins of the cooling head, use a hot plug, richen the motor.
shanem121 is offline
