She's got too much captain!
Hyper .21 3 port ( I think)
I think i may have flooded the engine. A couple weeks ago i took off the cooling head and wiped a little synthetic ATF on the Sleeve and piston. Now when i try to fire it up, it just doesn't. P/S Wet and fuel/oil mix coming out of exhaust. How can this be cured and does anyone know the stock settings on the carb, i have read the manual on ofna's site but i was wondering if you had some good settings as far as running goes. |
Take the plug out and turn it over either on a starter box or with whatever method you use to start it. The excess fuel/oil will come out the plug hole. Then reinsert the plug and go.
Originally Posted by jwm2
(Post 8047852)
do as suggested above , then use new plug |
ATF
If you mean Automatic Transmission fluid??
I would try using standard After Run Oil. This is recommended for Nitro engines. Also, Maybe you can clean the glow plug off with a little nitro spray. Be careful. Don't use the glow igniter right after. Let the glow plug dry before igniting. If it doesn't work, get another glow plug. Also, as some one said, clean out the excess ATF. I might stay away from ATF in the engine. |
Originally Posted by Dr. Evil
(Post 8048940)
Originally Posted by houston
(Post 8047883)
your plug is full of synthetic atf and possibly fouled ;)
(Post 8047852)
ALot of ATF's synthetic or Dyno have firction modifiers in them, which is grit, and it could very well could have messed up your compression..
Before you go any further, dissassemble engine, and rinse it well with nitro fuel.. |
Originally Posted by (MRC)Scotty!
(Post 8050168)
Try another plug and see what happens. You might be rich on the needles and that could be the cause of it flooding, i'd lean out the hsn just a tad and see if that helps.
(Post 8056174)
• MASTER NEEDLE - HSN) 4 TURNS OUT • LOW-END(BLK) NEEDLE (LSN) -3 TURNS FROM FLUSH • MID/LOW-END(BRASS) NEEDLE - NO TURNS I've tried the stock or reset to normal running, and then adjusting from there. And what i've tried on the HSN is from 4 out all the way down to 2.5 out. As for LSN, i've tried from 3 down to 2.5. I always double checked i was primed and that the plugs were glowing and now i'll try stripping it down and cleaning it and rebuild it to see if that helps. Would it be okay to use a little bowl of the fuel i'm running to clean them in or what do you recommend cleaning the internals with? |
Well try this first. Take the glow plug and back it out about 1/2 turn and then try to start it. Sometimes if the engine has too much compression it'll flood and not start up like it should. Just loosen the glow plug a tad, get it fired up and then tighten the glow plug back down.
(Post 8056605)
Btw, thanks for helping me. :nod: |
Well if no fire up then you have issues some where so do the rule of cancelation. Step 1 full dissasemble and clean then reassemble. Clean carb aswell and make sure ur nipples arent clogged. Once youve clean it all from crank to button, then install new plug and put some after run oil in it and work the flywheel back and fourth. Step 2 do the compression test, see if the motor even has life in sleeve still. Step 3 once all above has been done and all seems good put fresh fuel in it and try again, sometimes i will prime it and put a lil in the carb so it will start right up. If still no start then the atf has ate the engine beyond repair and it would be time to cut ur losses and learn from ur mistakes.
Originally Posted by NitroXray80809
(Post 8057137)
Originally Posted by Locum51
(Post 8057191)
Yea, what do you recommend as far as cleaning the internals?
Mmk. Thanks for all the help! I'll try to keep this thread updated after i tear down and rebuild the engine.
| All times are GMT -7. It is currently 10:36 AM. |
