-   Offroad Nitro Engine Forum (https://www.rctech.net/forum/offroad-nitro-engine-forum-157/)
-   -   Os speed runch rich (https://www.rctech.net/forum/offroad-nitro-engine-forum/439698-os-speed-runch-rich.html)
michaelfox 10-02-2010 12:27 PM
Os speed runch rich
i have had some issues with my os speed engines.
idles great and all day,trow it onto the track and it runs great on top.
i have problem clearing small dobbles and tripples...clears big jumps with ease, as long as i have a couple of meters run up.
only issue is it gets richer on bottom when engine is run for 2-3 mins...feels like its getting richer anyway :)
have checked for leaks,new bearings checked for slop in setup.
hope i made myself clear?:lol:
anybody has any ideas?
deadmancourt 10-02-2010 12:38 PM
ummm....lean the bottom a little!...problem solved!
wingracer 10-02-2010 12:46 PM
Never tune a cold engine. Tune it at temp. If the bottom is too rich when warm, lean it. If it idles too high after that, back off on the idle.
michaelfox 10-02-2010 12:50 PM
okey ill have a go tomorrow.
but i do belive its lean enough on the bottom.
i always warm up my enigine before i run it, so it has like 3-4 mins getting up temps before i drive each heat. and i also preheat engine with hair drier.
the engine is warm before i trow it onto the track.
wingracer 10-02-2010 12:57 PM
That's great but the motor still isn't up to full race temp, the chassis hasn't fully heat soaked, etc. ANY motor will run a bit differently a few minutes in than it does when it first hits the track. That's the whole reason for having a few minutes warm-up period before the race starts.
michaelfox 10-02-2010 01:06 PM
let me be even more clear :)
we have heats of 5 mins, 3 mins warm up before that, prior to that i warm up engine for 3-4 mins on starter box, prior to that i use hair drier for a while to pre heat engine.
so thats total of 6-7 mins of engine running before heat starts, do you still think its not warm?
i will try to lean out engine on bottom even more se if it helps.
i have a ninja jx and it runs great all day with same warm up procedure :confused:
just concidering what to do with this, leave engines be or chuck them in the bin.
next season i will have 4 REDS engines to play with som my last season with Speed. 99% sure
zuperbergen 10-02-2010 01:20 PM
I think you suck mike...:sweat: Skru inn til den gløder. Og så et hår ut igjen:lol:
deadmancourt 10-02-2010 01:23 PM
?:weird:
Frank L 10-02-2010 01:28 PM
A rich engine does not have an air leak. Air leaks make the enginenrun Lean. It needs to be adjusted.
AndyF 10-02-2010 01:36 PM
Wind the needles in and report back with where they are set.
Remember to pull the carb open when doing the low needle.
Also which speed, pipe and fuel?
michaelfox 10-02-2010 01:49 PM
pay zuper bergen no mind :sneaky:
using ninja 2042 exaust, odonnel 30% fuel. os p3
its the os speed vzb 21.
ill check the needle setting. get back to you tomorrow.
Stubbs 10-02-2010 02:18 PM
If you decide to "chuck it in the bin", let me know....I'lll pay for shipping and you can use my bin. :-)
deadmancourt 10-02-2010 02:31 PM
:lol::lol::lol::lol: YOUR BIN :lol::lol::lol::lol: :lol: i havent laughed like that in a while!...thank you!...that is PURE GENIUS!:nod::ha:
Stubbs 10-02-2010 08:06 PM
Never hurts to ask right? :sneaky: :lol:
j_blaze14 10-02-2010 08:07 PM
it may be lean on top with too rich a bottom, i say richen the hsn 2 hours and lean the lsn 2 hours.
