OS VSpec Removing Piston
Old 09-27-2010 | 04:18 PM
So*Cal AFDude's Avatar
Default OS VSpec Removing Piston
Well I recently broke the con rod on my VSpec , lucky for me everything else looks to be undamaged. I can see in the manual that there are E clips on the piston rod in the piston. How do I go about removing these so I can get the piston removed from the engine? Also does it take a special tool to pull the sleeve? Thanks!
So*Cal AFDude is offline
Old 09-27-2010 | 06:09 PM
cordarrow's Avatar
No need.....you remove the sleeve, then everything else. Normally you'd stick a zip tie through the exhaust port and roll the piston up to start the sleeve out of the case...with a broken rod you're left to improvise...
cordarrow is offline
I tried the zip tie method and pushing on the broken con rod but I cant get enough pop on it due to being broke. I can wedge a flat head through the backplate but Im afraid ill gash where Im prying on it.
Old 09-27-2010 | 06:19 PM
cordarrow's Avatar
no no....no flathead. Take it to someone with experience.
Old 09-27-2010 | 06:32 PM
draggin87's Avatar
Sometimes when a rod lets go it hits the bottom of the sleeve bending it slightly. That might be why it wont come out of the block
draggin87 is offline
Old 09-28-2010 | 08:12 AM
DOMIT's Avatar
From: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
+1 If the rod broke, chances are the piston and sleeve are thrashed too. And possibly the case, the crank, etc... depends on what hit what and how hard.
DOMIT is offline
Old 09-28-2010 | 09:33 AM
token's Avatar
you need to heat the bad boy up to get the sleeve out. No flathead or you will break the piston. There is a chance that the piston and sleeve are messed up but not a great chance.
token is offline
Old 09-28-2010 | 10:21 AM
Suspended
X2 Try about 150-165* to start. Much above 200* and the bearings will want to fall out.
I've had some that just holding the block in your hands for 5 min opened up them enough to slide the sleeve right out. Some take some heat.
Fire up the oven, make sure the old lady's gone and chuck it in @150. Let it sit for 15 min and pull it out(use a potholder..it'll be 150* LOL ) Try the sleeve by hand, it should want to slide out. If it won't, or isn't getting loose, bump heat to 200* and try again.
Like I said, above 200* the bearings will fall right out, so try and keep temps below that.
Storydude1 is offline
Old 09-28-2010 | 12:56 PM
thanks for all the replied guys! Im going to go try the oven trick right now. The way it broke was on the starting box. Got it started and burped the throttle a bit to clear it out and pop. I'll post if I have luck getting it out.
Old 09-28-2010 | 01:02 PM
Suspended
If the bearings DO come out, just pop them back in before it cools, or re-heat block and slide them in before rebuilding.
Getting them out and the crank out might be a good idea to see if it sucked in any shmeg past the rear bearing
Old 09-28-2010 | 01:05 PM
deadmancourt's Avatar
thats why they say to pre heat your engine!...i bet it was reaalll cold and as soon as you hit the throttle! SNAP! lol...i hate that! make sure you take the carb and ALL plastic parts off of the motor before you throw it in the oven!
deadmancourt is offline
Old 09-28-2010 | 01:44 PM
haha i need a heat gun ..never had the prob with my other vspec or rb though. too bad they're at 8+ gallons
cooking my vspec right now, thinking of tossing in some hash browns to go in with it
Old 09-28-2010 | 01:46 PM
token's Avatar
Upgrade to the speed ROD and you will be set.
token is offline
Old 09-28-2010 | 01:49 PM
i think thats what it had. it was the pro mod, i believe it comes with the speed con rod but not 100% sure
Old 09-28-2010 | 02:04 PM
might aswell throw in them hash browns! lol...
