Cant Get my sleeve out of the case.. any suggestions?
you can make it easier to come out by heating the case with heat gun then use zip tie stick it in the exhaust port and up and out the top then turn crank this should pop the sleeve up enough so you can get it out some times you have to put the square end of the zip tie in the exhoust port to push it up if this does not work then i dont know this is how i get all of mine out
I use a chopstick. then grab the crank with a pair of pliers, where the threads are, and gently turn it, just until it pops up a small enough ammount to gently pry it with a flat blade screwdriver, with chopstick removed....
A sleeve puller sounds great. Won't need it often, but when you do, it would be the safest way....
....just keep your flywheel on and use a glow plug wrench on the flywheel nut to turn the crank! and then anything plastic that will fit inside the exhaust port!
R/C Tech Elite Member
( in my best imitation of the miz) REALLY ? _
From: 4373 Creek Road Chaffee,NY 14030 USA (716)783-5198
RayAracing
