Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Innovative Designs ''Stacker'' Venturi >
Old 09-15-2010 | 07:56 PM
  #16
Suspended
Originally Posted by maxflo777
A taller venturi makes the "intake runner of the engine longer - the distance from the restrictor's "trumpet" or "mouth" to the rotary valve in the crankshaft. Since, the pulse waves that travel through it need more time to do so making tune at a lower rpm setting thus giving better power at low - mid rpm range.
In other words, same as long or short pipe/header.
same as pipe: long(tall) for short tracks, short for long tracks.
Actually, the gasses traveling through the intake runner and exhaust when tuned (when both have the correct length for each other) correctly "think" that both trajectories are equally long, the physical difference being "disguised" by the fluid's temperature.
xe
someone's spent some time near a flowbench
Storydude1 is offline
Old 09-15-2010 | 11:54 PM
  #17
Tony Newland's Avatar
Intake runner length is measured below the carb Hilborn Injection uses injector length to tune airflow deficiencies due to irregular intake runner lengths.... long ones go on the short runners to SLOW the airflow
If anything make different length heat dissipating carb sleeves (installed below the carb) different lengths, that would allow a usable tuning difference.
We're dealing with ultra high RPM "diesels" not a std 2 stroke gasoline engine and full scale automotive race engine. Dynamics that are present in our R/C engines are not present in full scale. I worked for a nationally renoun cylinder head builder here in town for 8 years (contracts included Yates and Hendricks)..... flowbench and dyno is all we did
Tony Newland is offline
Old 09-16-2010 | 07:10 AM
  #18
This is true for a multi-cylinder engine with a common intake manifold, where an "atmosphere" is created and where the pulse waves from the tuned runner length can work with. On a single cylinder engine like ours the runner is from the top of the restrictor to the crank valve, and the atmosphere plays its role as it is.
runner length ends where a sudden big change in cross sectional area is, and starts with the valve.
I would love to have your job that's got to be a daily school!
xe
maxflo777 is offline
Old 09-16-2010 | 08:30 AM
  #19
Not as fun as it sounds.... I havent worked there for years. It was quite boring actually.
Old 09-24-2010 | 09:18 PM
  #20
wfo's Avatar
wfo
From: SO. CAL. Thunder alley, revelation raceway The Dirt -Perris RIP OCRC
I would like to try a innovative 6mm in my plus-4 how do these fit in the novarossi carbs , snug like stock or to loose?
wfo is offline
Old 09-25-2010 | 06:01 AM
  #21
scoobie1's Avatar
scoobie1 is offline
Old 09-25-2010 | 06:25 AM
  #22
Locum51's Avatar
I can see where they changed the venturi up a bit but i would like to see a venturi that has something like this:
http://www.summitracing.com/parts/TAM-KI-80/
Locum51 is offline
