Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Clockwork Racing Engines and Products... >
Old 04-05-2013 | 06:23 PM
  #7171
PimpinTrugg's Avatar
Thumbs up
Originally Posted by rider313
I am good friends with the guy who did the laser etching. Yes they were done with a laser. It takes him about 30 minutes to get everything right. He did this with some spare time at his work. I don't think he has the time to do 50 custom CRE heads. Lol
Damit Janet!!!
PimpinTrugg is offline
Old 04-05-2013 | 06:31 PM
  #7172
Maximo's Avatar
Originally Posted by PimpinTrugg
Damit Janet!!!
Its no issue...
Maximo is offline
Old 04-05-2013 | 06:37 PM
  #7173
Got that P5 out on the track again today, this thing rips!!!! The run time is insane and tunes so easily. My hats of to you guys, there were a lot of questions coming my way about who built it and where they could get one.
vnviper is offline
Old 04-06-2013 | 11:15 AM
  #7174
Finally Josh is getting to run some nitro at round 1 of RC Pro series north. P5 and Bonito are flying, he was 5th in Pro buggy and 6th in Pro Truggy in 1st round of qualifying and the looking to move up as the day goes on.
Jeff Ford is offline
Old 04-08-2013 | 11:44 AM
  #7175
sschultz's Avatar
Hey Neil, so I ran my cre b6 pro this past weekend and it dropped it's nut's. WOW! It's a screamer for sure! I'm running a 2058 with 30/9 byrons and a p3 plug. My issue is the idle is hanging high to the point of the clutch almost engaging with 1.1 springs. It hangs for about 30 to 40 seconds. My idle gap is proper (.5mm) and the lsn is flush. I stopped at flush(I was richening to get idle to come down which did nothing) cause I figured if I had to go beyond flush, I have other issues. When it comes off the high idle, unless you catch it with the trigger, it dies. I'm thinking it dies cause I'm so rich on the lsn. I also think its a leaking front bearing that's the root of my problem. Can I get your .02?
NOTE: It runs great other than the high idle. 220f
sschultz is offline
Old 04-08-2013 | 11:49 AM
  #7176
McD44's Avatar
Hey Shane, I had the same problem with a Werks B5. It wasn't Clocked but a similar engine nonetheless.
It was a leak indeed but after I replaced my front bearing and it was still happening I had to look elsewhere. I found it to be at the carb/case joint. New O-rings + proper assembly the problem went away. I did end up needing a new front bearing anyway so no worries there.
I'd go ahead and check to make sure the carb is seated and everything else it tight then check the bearing.
Neal has a good way to check for front bearing leaks. With the engine idling on the box spray a little brake cleaner between the flywheel and case. If the engine stalls there's your leak.
McD44 is offline
Old 04-08-2013 | 12:12 PM
  #7177
sschultz's Avatar
I know of the spray behind flywheel deal. I have the stock ae flywheel on it and they kinda cups the bearing housing so it's a pita to do without getting blasted in the eye's with break cleaner. I've done it. All oring's where good, not saying one didn't get scarred or ripped when I put engine back together. I will check it out. Thanks for the info...
sschultz is offline
Old 04-08-2013 | 01:25 PM
  #7178
McD44's Avatar
Wear your safety goggles brother lol.
It never hurts to check everything out when you're having a problem. Sometimes it's the stupidest thing causing it.
McD44 is offline
Old 04-08-2013 | 01:34 PM
  #7179
Maximo's Avatar
Spider sense says we need to check your throttle linkage !
Maximo is offline
Old 04-08-2013 | 02:01 PM
  #7180
sschultz's Avatar
Linkage is good. Im anal about proper set up. It's a leak, pretty sure. It started doing it after a few tanks of fuel and the outer air filter element was getting pretty dirty. I was thinking, maybe it was starting to choke the engine for air and that might have finished of the seal on the bearing(air took the path of least resistance). I thought the seal was suspect last summer when I ran it cause it was pretty wet around it, but I was running a bit on the rich side yet so I shelfed it and thought nothing more of it. Anyway, new bearing on the way and will inspect all orings and replace as needed.
sschultz is offline
Old 04-08-2013 | 02:18 PM
  #7181
Maximo's Avatar
how much space do you have on your stop collar at neutral ?
Maximo is offline
Old 04-08-2013 | 04:18 PM
  #7182
sschultz's Avatar
Zero. Its spring loaded and I have a rubber band on the carb. I checked to make sure linkage or slide wasn't hanging up when it was doing the high idle thing.
sschultz is offline
Old 04-08-2013 | 04:54 PM
  #7183
Maximo's Avatar
usually it is the linkage..... not much else will cause what you describe...... basically it is acting like someone is holding the throttle open right ?
maybe give me a call later and we can go over a few things...
Maximo is offline
Old 04-08-2013 | 04:57 PM
  #7184
I think you missed what he was asking. I could be wrong though.
Chris Reilly is offline
Old 04-08-2013 | 05:15 PM
  #7185
You should have some gap between the collar and linkage. Neil should be able to get you dialed in though.
RandyJones is offline
