The New Werks B6 .21 Buggy Racing Engine!
#4186
Just my 2cents worth maybe you should try a Werks #5 glow plug and then re set your jets to flush . Then see what you have.
#4187
I will check that. Without looking I'm going to guess about 1.5 turns in from flush, but I'll check when I get home. One thing I read so often is that just go back to flush on both needles and start over which is what I did. I followed Griz's procedure from the Werks New Zealand site. But when I star that way it is so rich that I can't even keep it running with the .5mm idle gap, so I have to immediately start leaning the bottom some to keep it running. Then its so rich on top I can't clear it out with a WOT blip because it just loads up. So I only blip a quarter to half at max, will that clear it out or not?
In any case to test idle run a couple of laps and get the engine and chassis heat saturated and up to temperature (this is very important before you do any kind of tuning). Then bring the car back into the pits, grab WOT for 2-3 seconds to blow out any fuel accumilated in the crankcase then immediately hit brakes and listen to what happens to the idle. Idle should drop to a low idle and stay there. If after chopping throttle the idle is initially high and then starts to drop down lower (and or ultimatel conks out) that is an indication of the HS being lean and the LS being rich.
Obviously from reading that if you go to WOT and then chop the thottle and the idle is high that means the HS is lean. If the idle does not drop back down to a smooth, steady idle but stays elevated that also means that your LS is lean. So....you are too lean on both needles which is confirmed by you saying that you are 2 turns in on your LS which is about 1 to 1 1/14 turn leaner than I've ever needed to run it my self, so way, way too lean!
Then in this post you stated:
Good again, that is basically the same as the tuning method that we came up with.
So the only way to get completely out of whack like you are right now with as you say the engine being really fast on top end but showing little smoke and having an idle that does not come back down etc. etc. is by not following the procedure of adjusting your LS first to set idle, then adjusting your HS followed again by adjusting your LS to maintain a proper idle. So...please go back to flush and flush on the needles again, fire the engine up, set the LS so that you have a smooth, steady idle then take a couple of laps to warm up everything and start adjusting your HS to give you the top end that you need. Each time that you adjust your HS, check the idle and adjust your LS to compensate for how the HS adjustment is going to affect your fuel delivery. Do that any you will be fine. Hope that helps!
#4188
You can easily get that flameout issue corrected, you just need to tune the engine properly Right now your needle settings are completely out of whack, please do not run it anymore as you have it set now because it is extremely lean and you risk damaging it. You mentioned that your low speed needle is 2 turns in from flush, just out of curiosity where is your HS at? Let me know and I'll get you sorted.
#4189
#4190
I am also at about 3200 ft above sea level, I know altitude affects tuning.
#4191
The first time I tried the Werks method(before this series of posts) of LS first then HS, I thought it worked well car went up and down the street in front of the house behaving nicely. Put the car up until the next race day about a week later with similar weather. Didn't touch the needles, put it on track I began having issues again with the same settings that ran fine at the house a few days earlier.
Now I think its safe to say that the most common recommendation on nitro tuning is HS first then LS. The Werks method is LS first then HS, then adjust LS again. What advantage is there to adjusting LS first if in the end you have to re-adjust it after setting the HS?
#4192
In a nutshell you set the LS needle first (around a fixed idle gap) to gain the correct relationship (air fuel ratio) between the two.
Without this being set you can chase your tail all day long in an effort to "luck it" unless you have an experiancd ear and a full understanding of what is actually going on inside the engine / carburettor.
If you start with the HS first you are very likely to end up altering the idle screw to get what you think is the right mixture / idle speed. That means your now juggling three needles at once instead of two - an exponential leap in difficulty if your not an experianced tuner.
As Ron also explained, the HS needle (by vitrtue of how these carbs function) directly effects the fuel supply to the low speed needle - therefore altering it's setting. That's why your better off to set the LS needle first to get a reference point if you like, then get the best WOT performance you can with the HS needle (which will as we have discussed slightly change the low speed seeting). But because you had the correct idle speed as a reference point for the LS needle setting - you can now reset the idle speed back down using the LS needle and bring everything back to a balanced tune (or balanced needle settings if you like).
Think of your carb as a garden hose. The tap on the wall is the HS needle - setting overall flow parameters.
The adjustable spray nozzle on the end of the hose is the LS needle spraying fuel into the carb at idle.
What happens if you turn off the tap a little ? The flow from the nozzle lessens - so your engine runs a little leaner on the LS needle, and beacuse your idle gap is constant the engine will lean slightly and the revs will rise.
To faciliate this you need to open the spray nozzle a little further to maintain the flow.
Going a step further with this analogy - if you close the tap on the wall too far, ie overly lean the HS needle - you will get little to no water out of the nozzle. This is your classic lean bog scenario when the HS needle is leaned too much.
Think of your carburettor as a garden hose and I think it will help you to visualise what is actually taking place when you adjust the needles.
In order for this to work though - the idle gap (or in the hose scenario the size of the nozzle jet the manufacturer sets - and you can't adjust) must stay constant.
Hope that helps
#4193
#4194
I like that explanation! very good!
You need to read Ron's very thorough post again in depth. It's all explained in there fully.
Hope that helps
Hope that helps
#4195
Apco1, if the first time that you used our method it worked well then it will work well the second time. Also when you are tuning your engine if it is se/tuned properly at the end of one day, you put it away then take it back out and fire it up a few days later and as you mentioned absolutely nothing changed i.e. the air density, humidity and temperature then the engine will run exactly the same as carburetor can not adjust them self.
If indeed something has changed just pay attention to and listen to your engine on the box and it will tell you what is going on. Meaning if you put it away tuned perfectly with a perfect idle and fire it up and now and after warming up on the box for a few minutes (IMPORTANT, never bother tuning a cold motor) your engines idle is suddenly higher it's the engine telling you that "hey, look at me! Something is different, my idle is high that means the air is denser and I have leaned out!". So you can immediately tell that the engine is lean and when it leans out it leans out accross the board. So you have to richen your needles. If when you fire it up again, warm it up on the box and then check idle it is low then you know that the air is less dense and it has richened the engine up across the board and when you go on track you will have to start leaning it.
Now the one thing that sets off warning bells for me is the part I undelined:
Funny enough we used to sell them then everyone started doing wraps for their cars a few years ago. So no one bought stickers anymore and we stopped selling them. Now people are starting to ask for them again so we will just be including them in the box with engines in another month or two.
#4196
That garden hose analogy is an excellent one.. Good job. That should be a sticky somewhere, or in a youtube how-to video.*
I haven't seen that before, but I like the explanation about doing LSN first with the idle gap, then HSN, then re-adjust LSN. Makes sense. I have never thought about it that analytically, but over the years in very general terms my take on nitro tuning has become basically "it's all about the idle gap and having the right idle level", and the idle has more to do with the LSN - the HSN setting is in a way secondary. Well "secondary" is perhaps not the perfect word to describe it. But again, in very simple terms, a good tune is mostly about the balance between the idle gap and the LSN. The HSN you can tweak on top of that depending on weather or whatver... But the idle has to be right first and foremost. Which very roughtly put is similar to what was explained above..
* Actually, it should have been 6-7 years ago when nitro-hating flashlight drivers started badmouthing nitro has being "too difficult" bla bla.. Or when Losi started introducing stupid wannabe' gas engines based on the same false premise..
#4197
http://www.rctech.net/forum/offroad-...ng-engine.html
#4198
I'd heard about the "Werks method", and read it at some point on here probably, but always sort of thought of it as something specialized, and - no offense - perhaps a bit too complicated in the explanation. People need simple explanations, and the garden hose analogy makes it seem much more accessible. I have seen people refer to it over the years, so it's obviously been a good thing for some folks..
But unfortunately electric people, Traxxas-pushing hobby McChain shop employees, and now Losi and co., have really pushed through the false idea that nitro is "difficult". Which is ironic in the case of Losi, given that a decent nitro engine is WAY easier to break in and tune than their dumb attempt at a gas engine..
#4199
We used that garden hose comparison a few years back on the GO engine thread on here that was quite a prolific thread back then.
A lot of guys struggled with the long needle carbs that GO introduced and the garden hose thing helped a lot of guys to "see" what was actually happening inside their carbs.
Guys struggle a lot with the large idle gap scenario - what we affectionaltely call the "average woman tune" (sorry ladies) - lean on top with a fat bottom and a wide gap............
Tuning the way Ron has explained will totally prevent you ever getting into the wide idle gap and rich bottom end / lean top end situation, because you set the relationship between the idle gap and LSN first - from there it's hard to go wrong.
#4200
Wow...! Talk about the best customer support and service in the business...
