Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
The New Werks B6 .21 Buggy Racing Engine! >
Like Tree57Likes
Old 04-12-2011 | 02:20 PM
  #1546
Originally Posted by WideOpenThrottle RC
I'd open it up a little bit since your on the low end of the idle gap setting as long as your sure your bottom isn't rich.
ill do that..i think i got my low speed down packed i think its just the idle gap i gotta fix..ill open it a hour or two this weekend ill post up what happens...thanks again for the help
ajp165 is offline
Old 04-12-2011 | 02:38 PM
  #1547
blktransam's Avatar
Ron is 100% correct on the front bearing issue. but the bearing was leaking exsessivley in one spot and it looked like the seal was damaged in the same spot. I am going to run the engine prior to replacing the bearing and see when it is doing. if I can not get it to run "correctly" I will replace it and see what happends.
blktransam is offline
Old 04-12-2011 | 06:44 PM
  #1548
Originally Posted by Buster661
Ron, last weekend I had a radio issue and my B6 went wide open on the box. As expected it blew up and when I disasembled it I found only the Rod and Piston broke. My question is where can I get a rod from since AMain has them on backorder with no date. I figured I would ask since your so go about responding :-)
Thanks....
Hi, rods should have been here monday along with a bunch of other stuff but unfortunately UPS again misplaced one of my shipments lol! So if you are in Ontario and brown happens to leave a hundred plus engines, a bunch of parts, 600 or so glow plugs and some other stuff at your door step then you got my shipment from last week lol please let me know ;-) All joking aside I have another shipment of stuff heading out on Friday so if the last shipment does not arrive the new one will be here by the end of next week.
Werks is offline
Old 04-12-2011 | 07:09 PM
  #1549
Jack Smash's Avatar
I hope nobody took my earlier post about my leaky front bearing as a negative toward Werks engines. It was intended as an informative post about a tuning issue. The tracks we run at here in Nevada are notorious for killing bearings in general and have taken out many a front bearing.
It's just interesting that when I lost a front bearing on my OS Speed last year, you could see it leaking pretty much before it got impossible to tune. With the Werks, it isnt leaking much, but I could almost breathe through it when I was checking it.
Jack Smash is offline
Old 04-14-2011 | 05:01 AM
  #1550
blktransam's Avatar
is it friday yet?
Old 04-14-2011 | 12:34 PM
  #1551
Originally Posted by blktransam
is it friday yet?
I heard that!!!!! its finally outdoor time!!!!!
Mo Denton is offline
Old 04-15-2011 | 04:14 AM
  #1552
Guest
Default new b6
ok i read the first page, i understand it. but what about heat cycling the motor?? does it work on werks engine??? or just do what werks said to break-in?? how long of life can i see what of a b6??? i also have the 2013 pipe for the b6
LOSIRACER77 is offline
Old 04-15-2011 | 06:09 AM
  #1553
VWVR6_T's Avatar
There is a few different methods, Ron's method is the way to go in the Werks engines, due to the tolerance of the piston and sleeve. Do the brake in according first page and you'll be fine. At the half gallon mark you should be hitting the track strong and fast.
VWVR6_T is offline
Old 04-15-2011 | 08:05 PM
  #1554
Hey guys , just wanted to let any of you waiting on them that the B6 "Race Prep" engines shipped out to A-main today so they will bs in-stock on Monday!!
Also just curious if any of you have gotten engines recently and noticed anything different???
Werks is offline
Old 04-16-2011 | 10:42 AM
  #1555
rcfoxhound's Avatar
Default new
DO YOU MEAN THIS.
rcfoxhound is offline
Old 04-16-2011 | 10:55 AM
  #1556
hlpressley's Avatar
Hey guys I was looking through my distributors webiste and seen they now offer two versions of the B5 and B6. They have the standard in each and I now see a "Pro" version. What is the difference? Sorry if this had already been discussed.
hlpressley is offline
Old 04-16-2011 | 11:51 AM
  #1557
THE PHILLY JYNX's Avatar
wait and see!!!!
THE PHILLY JYNX is offline
Old 04-16-2011 | 12:04 PM
  #1558
blktransam's Avatar
MAYBE you should have pmd ron prior to that post
Old 04-16-2011 | 12:06 PM
  #1559
I saw it before the edit ssshhhhh.
one8updragracer is offline
Old 04-16-2011 | 12:08 PM
  #1560
hlpressley's Avatar
Top secret huh? Sorry, I didn't know. Just looking at bringing in some new mills for the shop and seen them.
