REDS Engines (Mario Rossi)
#586
#587
Alex, just curious, what pipe and manifold combos were Reds driver's using at the R.O.A.R nationals? LiveRC made a big deal about Adam Drake's 10min pit stops and I was wondering if Reds drivers were trying to match that by using specific pipes / manifolds?
Also, is after run oil recommended on Reds engines? I'm using Bryons 30 percent nitro w/ 9 percent oil. A friend of mine said to use Marvel Mystery Oil as after run oil and another said you don't need to use after run oil nowadays because the fuels have enough lube in them.
#588
Almost all competitors were having issues with run time there, combined with the wide open driving required, high heat and high humidity. Run times were all over the map. Regarding REDS drivers, most were getting between 7:30 - 9 mins. I was getting around 9 mins. I was running the 2099/S with 7.0 restrictor. I can't recall what our other drivers were running, but Cody was running a 6.0 with the 2104/XS. Me, Eddy and Cody were running Byron 30/8 fuel.
After run oil: I don't use it unless I am not going to run an engine for a while, at least 2 weeks. In general it is a good idea to do it to preserve the health of the engine just to be sure.
#589
cool. Thank you.
#590
I ran the 6.0 restrictor, XS manifold, and 2099 pipe. I think my biggest issue with runtime was that I like to run it a little rich and this track just wouldn't allow it. Maybe I need to start turning my EPA down instead of running rich. The motor just has so much power.
#592
Mine ( R5 + R5T-TE ) are still going strong! I have not had any issues, REDS is absolutely the best engines I have ever had :-) ..and I have had quite a few :-)
#595
reds clutch 1 carbon 2 aluminum all 1.1 springs ......
#600
