REDS Engines (Mario Rossi)
#2431
OK so one last review after the last race of 2021. I gave 721 SV one last chance on this weekends race. At first I was really skeptical of running this engine again but it was an expensive investment and I really wanted it to perform as it was advertised.
I put the stock carb back on and hit the track but this time I set the idle slightly higher and put on a brand new os p3 plug. Suprisingly with the idle slightly higher than what I would normally run with os speed or novarossi, SV performed perfectly. It is really fast and responsive.
One thing hovewer initially I ran reds 2143 with medium header then I changed the pipe to mielke efra 2041 turbo. I believe 2041 works much better but it is subjective. All in all REDS is great but you need to understand how these engines need to be tuned properly.
#2432
Break in procedure by Elliott Boots
#2433
He uses that smart machine now. I suggest EBIS.......
#2434
Jep
no „French fries“
Italian fries now. lol
no „French fries“
#2435
Anyone have the 721 Pro on order yet?
#2437
#2440
Do the S series pipes work on R series engines? I have an r5t. What's the best manifold and pipe or the proper manifold and pipe (for power) for these engines? I'd really like to try the new hard coated X pipe. Will it install well on an r5t? I don't want the pipe angled upwards with the downwards facing exhaust port. how has this worked for you guys?
#2441
The R series and S series engines have different headers.
Also you can have the Xone exhaust with angled header for the R engines and a straight one for the S engines.
#2442
I would recommend the X one exhaust made for the R series engines.
#2443
#2444
I am sorry but it looks like a lot of the R stuff is discontinued.
Amain has a combo left on stock you can use.
Pipe header combo amain
REDKM210009
Reds xone exhaust for R series engines.
KX210006 > X-ONE 2143 Torque> 2143 pipe welded to S manifold > featured by higher torque
KX210002 > X-ONE 2104 Torque > 2104 pipe welded to M manifold > featured by higher torque
REDKM210009
#2445
REDKM210009
REDKM210009
