TecnoPower Engine Thread ( From Rody Roem )
#616
What you need is a lsn you bought an air screw needle. Is the one you broke adjust the air or the fuel? If its the fuel u got the wrong part
#617
I bought the motor used and the slide was sticking. I pulled the IDLE screw out and found it was bent all to hell. Went to straighten it and it snapped. My low speed and high speed needles are perfect along with the rest of the carb.
#618
Seems like Amain put the wrong pic up, or has sent you the wrong part
Edit, checked again, and the screw in the package they show is the correct one
The package says partnumber: 0108060-01
#619
Heh, funnily enough Amain put a picture there of the actual idle screw you need. I was going on that.
Edit, checked again, and even the screw in the package they show is the correct one
I'm assuming this was the correct part just the carb has changed. Who knows. I'm only out $15 so I won't get mad about it.
#620
Ill take my GRP and pull the idle screw out, see what it looks like
#621
I have a guy sending me a grp carb now so no worries.
Here's my package:
Maybe it's a low end needle who knows.
#622
Strange indeed
The idle screw out of my GRP is exactly what is shown on Amain. It is the same as the Tecnopower idle screw you ordered. I have no idea why your idle screw is different. I do know that it says 1 on my GRP carb. Maybe there is a version 2 with a different idle screw?
#623
Strange indeed
Evidently they made a running change and I have an old carb because your idle screw is the same size as this techno one while mine is a lot bigger.
#624
Yeah must be
I found this pic of a GRP Ninja idle screw. If you look closely it is different from the idle screw that is in my GRP tuned or the Tecnopower engines. It looks more like your broken screw. Since the GRP tuned is based on the GRP Ninja you must have an early model GRP tuned and they made a running change like you suggested.
#625
Yeah must be
#626
I believe I just found one nip on ebay:
http://www.ebay.com/itm/MUGEN-GRP-NI...ht_1833wt_1163
I went ahead and bought it. Looks EXACTLY like mine that broke. Oh well at the very least I will have $10 in a spare carb for my other grp.
#627
I had a look at where i found that pic and it lists the GRP Ninja .21 idle screw as partnumber MR05008.
Could still be the same part tho but possibly listed under different partnumbers for the .12 and .21 engines. Fingers crossed
#628
It looks to be the same but it seems to be for the .12 engines.
#629
I know Technopower are closing there doors soon, but I noticed Amain are running these things out the door dirt cheap. Is it worth taking a gamble and getting one considering they are closing teh doors?
Am looking for a cheap truggy motor, which of the them would be the best option?
Would this here suit a truggy?
http://www.amainhobbies.com/product_...ned-Pipe-Turbo
#630
