The best glow plug ignitor??
#91
really? i have a couple dynamite lipo igniters and they work flawless, on one charge they last a good month of racing, bad luck must be on your side.
#92
glow stick
Ok I use hot shots for years! The only problem i got is the charger end comes a part. Is there a better charger for the hot shots????
#94
The RCATS system is nice, expensive, but nice.
#95
Its the plug end that goes in to the hot shot its self. It also ways shorts out and then I got to cut it off and weld the wire back on the plug.
#96
Surely you have a proper charger to charge other batteries like your receiver pack? Just make up or buy a glow plug charging lead and plug it into your charger. Use the Ni-Cad setting that just about every charger has these days to charge your ignitor. Problem solved.
#98
could just cut a hole in your box and pop one of these rigs in. mine has gone over 3 yrs strong. makes one less thing to carry/charge. no need to worry about lipo either, i went up to 4s with it. can get a box with one already on it for under $100 too.
http://www.google.com/products/catal...d=0CFQQ8wIwAA#
#99
Where can u order the RCATS others than RCATS website?
#100
hi guys is the hobbico hot shot 2 an NICD or NIMH and what mAh?
#102
#103
You must have had a bad Dynamite Li-po. I have one and it lights excellent. It will often start an engine that other igniters won't. I just wish dynamite would use a decent clip. Mine is worn out and won't hold now only after a few months of use. I tried bending the clips, but after 10 uses, the same problem occurs.
#104
