Ofna Force .21 JL
Old 12-29-2009 | 07:23 AM
  #196
pickle311's Avatar
nevermind, Aaron Joy hooked me up in the RB thread I just didn't see it. In case anyone else wants to know, the sizes are below.
rear= 14x25.4x6
front= 7x19x6
pickle311 is offline
Old 01-03-2010 | 08:22 AM
  #197
easyryder's Avatar
Got to race it at The Nitro Pit this weekend, switched to 30% byrons and p3 plug for the race and left the jp-3 pipe in place. The engine ran flawless both Qs and 20 min. main, got to really turn the needles to max power and it has tons, good on fuel, 8 mins to be safe. During the main I had it a little too lean and had to take it easy to keep it cool, mosty after the strait it would cut out a little when I really was pushing it hard around the track, after the race I had just under 1/2 tank after 7 mins from last pit. I have raced it hard for 4-5 races and it now has 3 gals or so, tons of compression, no oil what so ever at the front bearing, so far great little mill !! Lets see how long it runs for
easyryder is offline
Old 01-03-2010 | 08:44 AM
  #198
JUD's Avatar
JUD
That's a good reveiw!! Glad to here your doing good with it. Sounds like its really good on fuel? Looking at the videos of the pit, thats a pretty large track. I would assume your pinch is gone. It will more than likely run better now!
JUD is offline
Old 01-03-2010 | 10:36 AM
  #199
easyryder's Avatar
Its is good on fuel, I did have it on the lean side It still has a tiny bit of pinch with plug out, I love this engine so far
Old 01-03-2010 | 10:40 AM
  #200
Maximo's Avatar
so you ran 30% with 2 shims removed ?
Maximo is offline
Old 01-03-2010 | 12:53 PM
  #201
easyryder's Avatar
Correct
Old 01-03-2010 | 02:54 PM
  #202
Maximo's Avatar
Correct
Sweet.
tho I bet you found it likes to be a little richer... higher compression and higher nitro is going to need a richer setting for sure.....
Maximo is offline
Old 01-03-2010 | 04:49 PM
  #203
easyryder's Avatar
Hard to say, I leaned it a-lot at the pit, many things changed at the track, went up a clutch bell tooth, 30% fuel, bigger track, different elevation etc etc..... The needles are suprizinly close to factory, top is 3 3/4 bottom is 3 1/2 from close.
Old 01-06-2010 | 06:33 PM
  #204
JUD's Avatar
JUD
Just got my JL from AB Mods!! Looks very promising
JUD is offline
Old 01-07-2010 | 05:55 AM
  #205
easyryder's Avatar
Tight, lets see some pics!
Old 01-07-2010 | 08:06 PM
  #206
JUD's Avatar
JUD
HOW???? Ive been trying for the past 20 minutes!!! Thanks
JUD is offline
Old 01-07-2010 | 08:41 PM
  #207
Integra's Avatar
upload it to Photobucket and post the Img tags.
Integra is offline
Old 01-08-2010 | 10:09 AM
  #208
JUD's Avatar
JUD
Well I downloaded photos but I don't know how to put them on the RC tech site. But we have seen pictures of the JL before. Surely you don't think Im going to post pictures of AB Mods internal work!?!
JUD is offline
Old 01-08-2010 | 10:27 AM
  #209
Colt4g63's Avatar
Ah not much to see.. the crank is still all there and the sleeve is not cut to pieces. Just some proper timing adjustments and some of this and that
Colt4g63 is offline
Old 01-08-2010 | 04:43 PM
  #210
or maybe he dont really have one
jmoneym is offline
