ALPHA OFF ROAD ENGINES
#7294
LSN loosening
Hey guys need a little info form you...
So yesterday was the 2nd race day running my Alpha A852, my pit man was telling me that my low speed needle is loosening by it's self. he said he adjusted it to 2 o'clock position and when it came back in after race needle was passed 12 o'clock position almost to 11. How could I fix this issue? I'm guessing needle is backing off from motor vibration right?
I was think some lock tite might fix it but wanted your guy's input 1st.
thanks in advance!
thanks in advance!
#7295
Started break-in today and everything is going great. Although the engine is tight, it still is a pretty hassle free break-in. I think the biggest thing that might give people problems is the original plugs. If I would have missed Rex's post about it not working well, I might have had a lot more issues. Just like Rex and Lance said, the original plugs flame as soon as you take the igniter off the engine. I tried to make it work but after the second time, I just grabbed a OD 97T and it worked great.
I had to raise the idle and lean the HSN a little to complete the first tank and after that all has been smooth. I am only on tank 4 but have soom work to do and I'm hoping I can get back to it and finish it up today. I also shot a little video footage of how the engine is running during break-in. After I am completely finished, I will post it up. I can tell this engine wants to rev, even on break-in.
#7296
So yesterday was the 2nd race day running my Alpha A852, my pit man was telling me that my low speed needle is loosening by it's self. he said he adjusted it to 2 o'clock position and when it came back in after race was passed 12 o'clock position almost to 11. How could I fix this issue? I was think some lock tite but wanted your guy's input 1st.
thanks in advance!
thanks in advance!
#7297
thanks in advance!
thanks in advance!
#7298
thanks in advance!
thanks in advance!
Rex
#7300
thanks in advance!
thanks in advance!
How old and where did you by the engine from?
#7301
Got it about 3 weeks ago from link below, seller was in Canada have about 1.5 gallon thru the engine.
http://www.rctech.net/forum/r-c-item...-clearout.html
#7302
Putting fresh orings on it and problem solved.
#7303
EDIT: First couple of tanks, i kept chasing the tune. I changed the plug and she kept the tune like always.
#7304
Send me an email thru Triton RC and I will send you out a new low speed needle with O-Rings .
Lance
