ALPHA OFF ROAD ENGINES
#4591
Suspended
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
#4593
Suspended
cheers for the help. any idea where the ideal starting point(close to a perfect tune) for the LSN is(how many turns out?) not bang on because i understand that every engine is differnt but mybe 2 hours out from yours?
#4595
I run the Alpha F850 in my 1/8 LM. Let me tell you, that thing has some POWER! The problem i am having is that it goes from too lean to fuel spitting pig. I run 30% nitro with two shims in the cooling head, ODonell 97T plug on the A plus 0801 pipe. I have about a gallon and a half on it. The temperature around here has been 80 average. Does anyone have a needle setting suggestion for me to try? I like the idea of lean bottom/rich top. My motor feels good but I am new to precise engine tuning. I don't think I have tapped the potential of this motor at all. Any help would be greatly appreciated.
![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
#4596
Where do you run the exhaust on the LM, we ran ours through the bottom of the chassis and if the pipe got hit, it would move over and turn rich very fast from the exhaust not being able to escape. If your rich at wot turn the hsn in to flush or just below on an oval motor. Get the idle set good on the box, after the motor is good nd warm, when on the track it should almost ringting on entry and to the center bit not be a high idle.The 97t may be to cool for that head clearance, you could try a P4, I tend to stick with cooler plugs on the oval motors as well.
Hsn 1 1/2 to 2 turns in from flush
Lsn 4 1/2 turns in from flush... This is with the thicker end housing.
#4597
#4598
Should I take the shim out? I have heard that you need the shim in order to run 30%. Also, I am not sure what you mean about the thicker end housing. Like I said, Im kinda new and not hip to all the terminology. I run my exhaust out the side just like a buggy. Its got plenty of breathing room. And what is considered good idle? Just enough to stay running?
#4600
Suspended
#4603
does anyone know the measurements on all the o rings in the alpha carbs? i.e
high speed orings low speed orings and the lower carb seal block oring.
#4605
I thought I would be able to get away but it's my girls bday today
And I'm forced to do the family thing tomorrow, but I'm full blown every
Weekend starting next Sunday at hobby headquarters. I should be at next wolcott race and will grab that carb from you. Thanks.
