OS MAX 21XZ-R ~~FULL PHOTO~~
#76
looks good
#77
Yes i added a extra 0.1m shim, and changing from a metal to a ceramic bearing,i noticed the engine spooled alot smoother and faster, the bearing size is a 14mX6X25, same bearing size as the OS speed buggy engine bearing.this bearing in my opionion is the best Ceramic bearing on the market. i hope all this has helped.
#79
All, as far as I have been told by the UK importer, the new engines have now been re-released at the end of December are out now,
Andy
Andy
#81
New version
It looks similar with the current version on the outside.
New part number and it says on the stand "new"...
from www.rcspecial.com
#88
Maintenance
How many gallons of fuel have you but threw your engine and how is the con rod taking it.Is your compression still good.I have run a number of os engines they all had great compression in the beginning but after a few gallons it was not the same.Thats why I was going to go with a nova rossi engine,but this is my first 1/8 on road and wantned to keep it simple so I was thinking of getting one of these so how the maintenance on the motor have you checked the con-rod and bearing looked at the piston
#89
#90
What is the Front and Rear bearing size of this engine, thank a lot!
