Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
The New Werks B5 .21 Racing Engine >
Like Tree63Likes
Old 11-23-2009 | 05:13 AM
  #841
Default Remove shim 25% nitro
I understand that the engine comes prepared for 30% nitro.
Do i need to remove a shim when using 25% nitro?
daka is offline
Old 11-23-2009 | 06:09 AM
  #842
kgombe's Avatar
Originally Posted by heidmann1
Guys you will not be dissapointed with the B5 Got third in kyosho classic today in buggy and 4th in truggy running B5's in both and after a 20 minute buggy A main and a 30 minute truggy A main They temped at 220 deg and idled perfect never flamed out or gave any trouble for the 2 day event. ran 2013 pipes in both had gobs of bottom and I never got pulled on the 130 ft straight. ( approx) Against novas, sirios, ninjas and os speeds There was a lot of people amazed at the the race how fast these engines are and how cool they run. My pit man told me a couple other teams pit guys could not believe how the B5 was screaming! Then they heard my pit guy say 220 deg (after 20 minutes) they used there tempgun after the 30 minute main was over and it was 221 deg...Haha gotta love it! They said it was so fast they thought for sure it was runnin at like 270 deg. I also use Werks fuel so I am sure that helps too.
were you in the expert class?????
kgombe is offline
Old 11-23-2009 | 06:10 AM
  #843
kgombe's Avatar
no you do not....
kgombe is offline
Old 11-23-2009 | 08:48 AM
  #844
After reviewing the Reedy thread, I've decided the B5 is a better pick for me, so back goes the Reedy for the Werks. I have the 2035 pipe (2013 is out of stock), which I'm hoping will be a good low/mid match for the B5 and my mid sized home track. Any update on the ETA for the new, beefed up Werks 2013?
phm14 is offline
Old 11-23-2009 | 09:22 AM
  #845
junkee's Avatar
how did you know i was running a losi lol. two of my friends are also running losi buggies and had the same carb prob this weekend. the angles of the linkages are straight it seem to be binding more like the top of the slide on the carb body than trying to rotate it. kind of like its pulling the slide down and binding but everything seems straight. it just dosent feel smooth so ill be sure to try what you said to try and fix it . thanks for the info Ron
junkee is offline
Old 11-23-2009 | 10:08 AM
  #846
You need to make sure the linkage is level with the ball on the carb. If the ball is higher or lower than the linkage at the servo horn. It will wear and start to bind. It needs to pull perfectly straight. Some vehicle designs you will need to raise or lower the linkage off the horn, it also depends on the angle of the ball on the carb. I saw this happen to a guy at the track sunday who was running a picco engine. He had his linkage higher than the carb ball and it was forcing the slide up into the body everytime he pulled the throttle. Then it eventually just stuck. I gave the guy a old P7R carb I had in my box. and set it up for him. I think this gets overlooked a lot.
heidmann1 is offline
Old 11-23-2009 | 10:23 AM
  #847
hdcruzer's Avatar
I run the 2035 pipe and it works great lots of bottom and mid decent top.
hdcruzer is offline
Old 11-23-2009 | 02:12 PM
  #848
Good to know just smashed a New $100 Sirio 2057. Cant go through a pipe every weekend.
underway is offline
Old 11-23-2009 | 03:36 PM
  #849
so the B5 has been out for a little while now. Is there any agreement on what pipe works best on this motor? I am about to pick one up and I would like to know if i need to order a pipe too. I have a 2013 but most of the engines I have used it on have way to much unusable bottom. I am looking for smoothness and runtimes but it still must have enough bottom to make the big jumps and short run up jumps.
matrixmike28 is offline
Old 11-23-2009 | 03:55 PM
  #850
allan42r's Avatar
is that pipe a low end pipe? you had WAY more low end then me but i think you could've used more top end, maybe you had more left?
allan42r is offline
  #851
The 2057 is the way to go... It smoothes out the powerband and still has awesome bottom end...run time is great also. Only downfall is that its fragile. If I could find someone to hardcoat this pipe it would be a 10/10 for the B5.
underway is offline
Old 11-23-2009 | 04:02 PM
  #852
2057 sirio is a great match to the b5 alot of smooth bottem ripping top,ran last night 9:45 sec before out in a race she was screaming fast and only 205 degrees
jmudbug is offline
Old 11-23-2009 | 04:11 PM
  #853
hdcruzer's Avatar
Well Im ready to race..... This B5 is great so far. All broken in and ready to go. Just like I said in an earlier post the 2035 is a great pipe for this motor.
hdcruzer is offline
Old 11-23-2009 | 05:06 PM
  #854
TXRC8racer's Avatar
Found out today that Mike Battalie sponsored by Werks is running a JP4 along with a couple of other guys running this pipe and motor combo. Im a new proud owner of a B5 as well.
TXRC8racer is offline
Old 11-23-2009 | 05:12 PM
  #855
2057 smooths out the bottom , or 2056 smooths it out even more, both have xlnt top......all have great top but from most bottom to least it goes 2013, 2057 ,2056 and they are all xlnt pipes for the B5 it is just a preference on how you like it to feel. 2056 and 2057 have a slight mileage increase over the 2013 but not a ton .
