The New Werks B5 .21 Racing Engine
#2356
thank you for your response... i will start at a half turn in... and see how it goes...
#2359
Well, just put in my order for 2 B5's and pipes, for my brand new RC8B and RC8T.
Should have them installed by the end of this week, all ready for break-in this coming weekend.
I'm primarily an on-road guy, but I'm sure looking forward to messing around in the dirt.
This is gonna be fun!!
#2360
thank.. i read the instructions but assumed it was gear towards a buggy.. thats why i asked for a truggy what would you set it as.. i have the B5.. and soon to get the 2013 if it ever gets here... its a brand new engine.. so i still got to break it in before i really get into it
#2361
Regards,
Ron
#2362
What are the stock lsn and hsn settings from the factory, having a bit of a problem tuning the B5. It seems to running good but lacking low end and running warm 245. Pretty sure from reading other posts that its lean on the high and rich on the bottom. Also using the werks clutch and carbon shoes might try the rulon and carbon shoe combo. Also has anyone have problems with their idle screw? Mine seems to make the slide bind when i adjust the idle up.
#2363
Ok, just pull the engine apart and see if you see anything. I honestly don't think the motor is the issue though because if it was it would not run fine for 5 minutes and then start acting strange (unless it was too lean but it sounds like you took care of that concern). The issue that you are describing sounds like it might be a pressure issues, replace the tank as you mentioned and change the fuel line at the same time. Let me know what you come up with!
#2365
If your slde is binding when you adjust the idle up you probably have it close to mazes out. Flip back and find my tuning tips and it will set you straight on tuning the engine. In a nutshell set the idle to aprox .5mm, set the HS flush fire the engine and use the LS to set the idle. Run the car and set the HS for the top that you want and then go back and adjust the idle again with your LS and you will be set. I went into more detail in my explination a ways back but that's the gist of it!
#2366
#2367
For real change tracks! If you don't have that opportunity make it DANM sure that there knowledge of theives at your local. Get on yoiur local site and post about it so everybody kmnows that somebody stole your mill. An't nothin lower than a theif, so handle yours!!!!!! If you bought i legitamley(SP) you should let it be known that it is yours, and "just handing it over" an't gomna cut it!!!!!! On pratice days when im martialing and my boys are runnin, theres always those overlookers of the pit setup so i tell them to gp on for real.
#2368
My turn for a "my b5 rocks" story!
I followed the break in guide on page 3, stalled a couple of times while I was getting the (seemly) huge idle gap sorted out for break in. Had it heated up and idling in no time...
Idled the full tank like a train (Had oil all over my shirt so thats a good sign it's rich enough
Did the rest of the boring breakin (I hate breaking in engines...) with no flame outs for the rest of the 7ish tanks. Slowly leaning it off.
Had to wait 2 weeks till our next prac session, but I got it purring along with a good - but not 100% tune...
Had plenty of good sparring sessions with my mates OS Speed (My 808 Vs Hyper 9)...
I wouldn't say this engine is faster, but neither of us had a definite advantage anywhere in the Rev range. Ran the same plug since breakin... no problems all day
Running :
Ascendancy 4 Shoe Clutch 1.0 Springs
XRAY 16T Clutch Bell
TTR 2035 Pipe
OD 97T Plug
Ran for 10m 22sec on a full tank with this setup... (Only timed once however)
Not quite enough for me to pit at 10 - which pipe would get me some extra seconds? (Im not brave enough to risk running out of fuel
)Did the rest of the boring breakin (I hate breaking in engines...) with no flame outs for the rest of the 7ish tanks. Slowly leaning it off.
Running :
TTR 2035 Pipe
OD 97T Plug
#2369
Running :
TTR 2035 Pipe
OD 97T Plug
Running :
TTR 2035 Pipe
OD 97T Plug
#2370
I just hit the half gal mark on my first B5 today at our little track that we have and I had guys offering me $50 more then what I payed for the engine new they where that impressed as was I.
This has got to be the best engine that I have bought yet, break in was so very easy, holds a tune all day, and is to me for an engine of this quality dirt cheap. I can't thank Ron and all the people involved with the RD of it enough for what is going to be my engine of choice until Werks has something new out.
I'm just really glad I bought 2 right from the start and didn't hesitate.
I will say this the only thing that I wish it had out of the box was some STICKERS so I could plaster them all over and let people know what just passed them LOL
63Likes
... ama see yu at rama next year
